Power & Energy
Power & Energy
Forum Power supply plug with Forked-Shaped Contact
  • Subscribers 282 subscribers
  • Views 732 views
  • power supply plug forked-shaped contact cable
bernh
bernh over 7 years ago
I'm looking for a power supply plug with forked-shaped contact like this:
Farnell No.: 2677775
https://de.farnell.com/lumberg/1633-04/dc-hohlstecker-4a-12v-dc-kabel/dp/2677775?st=1633%2004
But:
with cable (~1500 mm) moulded, anguladet
Does somebody has any idea to purchase this plug with cable (~100pcs.)?
Thanks and kind regards,
BernH
    shabaz over 7 years ago +2 suggested
    Hi Bernhard, This looks like a normal 5.5mm/2,5mm connector (they nearly all have two small things on the inner area, which grips the centre pin, so the fork text may be confusing things (because there…
  • bernh
    bernh over 7 years ago in reply to shabaz +1
    Hi shabaz, thanks for your answer. My experience is, the most of buyable 5.5mm/2,5mm connectors do not have this things to grip the centre pin. But many original connectors for e.g. IT-components have…
    0 shabaz over 7 years ago
    Hi Bernhard,
    This looks like a normal 5.5mm/2,5mm connector (they nearly all have two small things on the inner area, which grips the centre pin, so the fork text may be confusing things (because there are non-standard connectors with outer metal with protruding fork).
    If the item that you have linked to is definitely what you are looking for, then the cables are available here:
    https://uk.farnell.com/w/c/cable-wire-cable-assemblies/cable-assemblies/barrel-power-cords?connector-type-a=2.5mm-barrel…
    For your length, it would be good to buy the approx. 10 feet or longer cables, and cut in half (because the cable has the same plug on both ends). So you only need to purchase 50 pieces.
  • bernh
    0 bernh over 7 years ago in reply to shabaz
    Hi shabaz,
    But many original connectors for e.g. IT-components have this...
    I will buy your suggested article and I'm looking forward for testing ;-)
