Power & Energy
Power & Energy
Forum We need a replacement for a relay.
  • Subscribers 283 subscribers
  • Views 555 views
Former Member over 15 years ago
We are a US manufacturer. Recently Iwent to order a relay for one of our products and found it to be dicontinued. I'm not
very good with the elctronics parts world so wanted to ask for help.
The part number was a Stancor Electronics #129-903
Plug-In Relay; Contacts:SPST-NO; Contact Carry Current:18A; Coil Voltage AC Max:120V; Relay Mounting:Plug-In; Relay Terminals:Screw
we just called in Relay 115 Volt.
Can someone help? Please reply to wds@esicotriton.com
Thank you.
Bill
    0 Former Member over 15 years ago
    Here is what the side of the unit sais.
    A.C. ONLY 250V 18A
    1 H.P. @ 125V-2H.P.  @ 250V
    COIL 115V 50/60HZ
    WHAT DO I LOOK FOR IN AN ELECTRONIC SUPPLY BOOK? image
    0 Former Member over 15 years ago in reply to Former Member
    Bill,
    As long as you only need something that does the same job, just look for a relay with:
    120VAC coil
    Contact rating of 250V @ 18A minimum (i.e. you can use a 20A or 25A relay)
    If you needed something form/fit/functional equivalent, that might be different.
    PS Realy Specialties say they have 23 in stock, if that helps ;-)
    http://www.relayspec.com/product_list.php?subcatid=45&sel_manf=113
    Post back if you still need help. I have attached a catalogue page showing the item.
    Jonathan Point
    imagePg_064_65.pdf
    Thank you for the tip Johnathan, I have put in an RFQ with RSI and will then be looking for the replacement for he 129-903.
    I appreciate your help.
    Bill
