Power & Energy
Power & Energy
Forum I need help designing a 400hz 115vac 3phase power supply -- Help
  • Replies 32 replies
  • Answers 3 answers
  • Subscribers 285 subscribers
  • Views 11752 views
  • power_management
  • 400hz
  • power_supply
  • power_conversion
phoenixcomm
phoenixcomm over 13 years ago
Hi I need to find a way to get 400hz/115vac/3phase cheaply..  Im a digital person...
any thoughts.
The unit could be powered from a 28vdc source but better yet 115ac house hold 15amp circuit
Cris
  • artful_bodger
    artful_bodger over 11 years ago +3
    If you are borrowing mil spec gear, they will not want it damaged, so you'll need to read the relevant spec and understand how to contain your supply within the spec. Too many harmonics and you'll most…
  • billabott
    billabott over 13 years ago +1
    Could this be what you had in mind? http://www.newark.com/schneider-electric/atv12h037m3/ac-drive/dp/11R1086
    michaelkellett over 13 years ago in reply to phoenixcomm +1
    Hello Cristina, I could give you some assistance but first I would need to know what you want to drive with it and what other constraints you have. This is not a simple project and if you only want one…
  • AK7466
    0 AK7466 over 5 years ago in reply to shabaz
    Hi Shabaz.  Thank you for your thoughts and comments, and taking the trouble to respond.
    As you say, I can add an extra inductance in series with the winding.
    What I would like to know is how to calculate the optimum value for the inductance, and whether it would also be beneficial to add a capacitor as well?
    Thanks again
    Alan K.
  • Batis
    0 Batis over 1 year ago
    I can help you complete this project
    I can build you a 115 volt, 400hz three-phase power source.
    With a power of up to 10 kVA
    I can put a 28 v 15 a output on this same power supply
