Power & Energy
Power & Energy
Forum Need to get MG Electronics Power Supply repaired...or NOT!?
  • Replies 120 replies
  • Answers 51 answers
  • Subscribers 285 subscribers
  • Views 14770 views
Hi.
I just bought a lot of Slot Car stuff, yes those cars that go around a track. The guy was serious about his hobby he didn't have the usual wall plug in power pack, he used a MG Electronics PS-10AD, 0-20 VDC at 10 Amps. Well this power supply doesn't work anymore. It does turn on and the red overload light stays on. It doesn't put out anything. I used my multimeter etc., nothing. I know that these are made overseas . They did retail for about $200. So the questions is were can I get it repaired OR should I ? I'm in Western MAss.
I did check the fuse , it's fine. I've got a heavy door stop on my hands, it does have a nice handle and cord on it !
Many thanks for info, Ted
http://www.mgelectronics.com/shopexd.asp?id=179
  • mpulliam
    mpulliam over 5 years ago in reply to jw0752 +4 suggested
    Well, I spent all day replacing four 2N3055 transistors....it wasn't easy and... Success!!!
  • mpulliam
    mpulliam over 5 years ago in reply to jw0752 +3
    Hi John, I have a thought. If the output transistors (or is it pass or power transistors?) NTE130 or 2N3055H are giving a bad voltage reading in the voltage test, could it be that any component between…
  • mpulliam
    mpulliam over 5 years ago in reply to mpulliam +3 suggested
    BTW I tested the old 2N3055 transistors, the continuity is the same as a new 2N3055 . There is no continuity between any of the terminals But when I run a diode test, a new 2N3055 tests at .486 volts with…
    0 jw0752 over 5 years ago in reply to mpulliam
    Hi Matt,
    I would get the 2N3055 as opposed to the NTE 130s if I had the choice.
    https://www.newark.com/multicomp/2n3055h/bipolar-transistor-npn-60v/dp/78M7081?st=2n3055
    You will also need to get some of these:
    https://www.newark.com/nte-electronics/tp0001/thermal-insulators-thermo-pad/dp/79M5626?st=to-3%20insulator
    Which can be used without thermal paste. If you want to reuse the current mica insulators, if they are in good condition, you will need to put a thin layer of thermal paste on the contacting surfaces. Be sure to install the insulators before soldering the wires to the pins..
    If you want to save on shipping you might check to see what your electronic store resources are in your city. I would be surprised if you couldn't find a local store that would have these two items though what you save in shipping might be offset by higher component prices.
    0 Jan Cumps over 5 years ago in reply to jw0752
    jw0752  wrote:
    H...
    I do that here. In Brussels there's a shop called Elak. They have loads in stock. And I can order anything from element14 / Farnell.
    Because they order from there, my components are a tiny part of their order.
    They have a markup. For most orders lower than what I'd pay for shipping.
    And I prefer to spend the extra money there rather than on FedEx/UPS - who try to make my life miserable whenever they spot the opportunity.
  • mpulliam
    0 mpulliam over 5 years ago in reply to jw0752
    and...
    Success!!!
  • mpulliam
    0 mpulliam over 5 years ago in reply to mpulliam
    BTW
    I tested the old 2N3055 transistors, the continuity is the same as a new 2N3055.  There is no continuity between any of the terminals
    But when I run a diode test, a new 2N3055 tests at .486 volts with negative on the emitter, and the positive on the base.  .OL in any other test configuration.
    The old 2N3055's test at .OL in every test configuration.
  • fmilburn
    0 fmilburn over 5 years ago in reply to mpulliam
    Hi Matt,
    Hurray!  Well done.  I am curious what the theory is on why these failed.  If I remember correctly it was working one day for you and the next time you turned it on it wasn't working.  Maybe John has a thought.
    Frank
    Congratulations Matt,
    You stuck with it and you won the battle. Your diligence in taking good measurements and notes as well as useful pictures made all the difference. I hope you stick around the forum and continue your adventure in electronics. Don't hesitate to share your projects. The next time someone needs one of these fixed you are the go to expert.
  • mpulliam
    John, thank you very much for your knowledge and ability to communicate it!
    Matt
    0 jw0752 over 5 years ago in reply to fmilburn
    Hi Frank,
    I think that the problem comes from the paralleling of the (4) 2N3055 output transistors. When the unit is used at High current and low voltage the 4 transistors have the challenge of getting rid of the extra power that is not being used. In a perfectly balanced system they would each carry 1/4th of the load and all might be well. Unfortunately they are not perfectly balanced and the one transistor that insists on taking more of the load gets hotter and hotter until it fails. In this case it seems that they fail open Base Emitter which takes the most ambitious transistor off line and transfers the load to the remaining three. One by One they fail until we are left with the situation that Matt had. The designer realized that this was a potential problem so they put emitter resistors on each of the Outputs as this helps to balance the load. This are the stretched out coils that we see on one circuit board. I am sure that they help but apparently not enough to prevent failure. Since we have seen two of these units with the same problem on the forum I would guess that these failures are a design problem.
  • fmilburn
    0 fmilburn over 5 years ago in reply to jw0752
    I thought that might be it.  It is a common problem in parallel systems whether they be splitting fluids or electrons unless there is some sort of active control.
    0 Jan Cumps over 5 years ago in reply to mpulliam
    If you open one of the old transistors, you will most likely find that one of the bond wires has melted inside.
