Power & Energy
Power & Energy
Forum Can someone provide me with teardown of chassis mount resistor tjt300 10R from TE
  • Subscribers 280 subscribers
  • Views 1484 views
  • resistor
manojroy123
manojroy123 over 2 years ago
Can someone provide me with teardown of chassis mount resistor tjt300 10R from TE. What kind of strip is used inside it.
    michaelkellett over 2 years ago +3
    I think this may be a case where you need to spend £50 and do your own tearing. (Watch out for toxic stuff inside !!) Why do you want to know ? MK
  • gordonmx
    gordonmx over 2 years ago +1
    The datasheet for the resistor says wire wound. Most likely nichrome. The 300 W rating is with a heatsink and is 150 W in free air. That would lead to 3.9 amps (R*I^2) for 150W. With a 2.75" x 8" body…
    shabaz over 2 years ago in reply to michaelkellett
    I think it's related to this one:
     Does anyone knows. How a duracell powercheck feature works ?
    Maybe trying to make that for a different battery! I thought Duracell Powercheck was a failure... don't see it on batteries these days because people got wise that it merely depletes the battery that bit more.
  • gordonmx
    The datasheet for the resistor says wire wound.  Most likely nichrome.  The 300 W rating is with a heatsink and is 150 W in free air.  That would lead to 3.9 amps (R*I^2) for 150W.  With a 2.75" x 8" body, that can be a number of turns.
  • phoenixcomm
    phoenixcomm over 2 years ago
     manojroy123 MG its a wire wound resistor enclosed in aluminum.  ie why care? The specs state XYZ.  Question why do you care? ~~ Cris
  • James123
    James123 over 1 year ago
    Generally, the TJT300 series typically uses wire-wound resistors internally. For specific information, I recommend directly checking the PDF to understand the basic technical specifications and some physical characteristics. I haven't found any related explanation videos on YouTube.
