Power & Energy
Power & Energy
Documents STmicroelectronics SPV1020 solar DCDC converter with MPPT
  • Author Author: doctorcdf
  • Date Created: 22 Nov 2012 9:47 AM Date Created
  • Last Updated Last Updated: 22 Nov 2012 9:51 AM
  • Views 825 views
Product Description:
The SPV1020 is a monolithic 4-phase interleaved DC-DC boost converter designed to maximize the power generated by photovoltaic panels independent of temperature and amount of solar radiation. Optimization of the power conversion is obtained with embedded logic which performs the MPPT (max. power point tracking) algorithm on the PV cells connected to the converter.
One or more converters can be housed in the connection box of the PV panels, replacing the bypass diodes. As the maximum power point is locally computed, the efficiency at system level is higher than that of conventional topologies, where the MPP is computed in the main centralized inverter.
Applications:
Solar inverters
Man Part No.
APAC & EU SKU
Newark SKU
Description
SPV1020
20980062098006
73T224473T2244
  • alternative_energy
  • solar_panel
  • stmicroelectronics
  • solar_converter
  • solar
  • solar_cell
