Power & Energy
Power & Energy
Documents Freescale MC56F84xx 32-bit MCU
  • Author Author: doctorcdf
  • Date Created: 22 Nov 2012 11:16 AM Date Created
  • Last Updated Last Updated: 22 Nov 2012 11:30 AM
  • Views 1292 views
Overview
The MC56F84xx is the market’s fastest digital signal-processing microcontroller, offering exceptional precision, sensing and control for the most efficient digital power conversion and advanced motor control applications. The MC56F84xx includes advanced high-speed and high-accuracy peripherals such as a high-resolution pulsewidth modulation (PMW) with 312 pico-second resolution, dual high-speed 12-bit analog-to-digital controllers (ADCs) with built-in PGA sampling up to 3.3 mega samples per second (MsPs) and one high-precision 16-bit ADC. Faster application-specific control loops are driven via a high-speed 32-bit digital signal processing (DsP) core with single-cycle math computation, fractional arithmetic support and parallel moves.
Features and Benefits
  • High-resolution PWM with 312 pico-second resolution enables higher switching frequencies, reducing cost and increasing efficiency
  • 2x 12-bit high-speed ADCs with up to 3.3 MsPs resolution improves system accuracy by reducing jitter on input values
  • 100 MHz/100 MIPs 32-bit core provides math capabilities needed for advanced power efficiency and motor control applications
  • 64 KB to 288 KB flash memory flexibility provides scalability needed for key digital power and motor control applications
  • single-cycle math computations, fractional arithmetic support and parallel moves improves performance, driving tighter and faster control loops
  • Direct memory access (DMA) controller reduces core interruption, increasing performance
  • Four analog comparators with integrated 6-bit DACs speed system event identification and emergency shutdown of the PWM outputs
  • 5V-tolerant I/O provides design flexibility and system cost reduction
  • Memory protection capability increases system safety by restricting user code from accessing key memory locations and peripherals reserved for supervisor access
  • Freescale’s FlexMemory EEPROM provides scratch pad for calibration and shutdown values
  • Market-focused software components, reference designs and development tools provide application expertise in the form of run-time software, schematics and other key time to market needs
Applications
Solar Inverters
Man Part No.
APAC & EU SKU
Newark SKU
Description
MC56F84441VLF
20955862095586
24W855324W8553
DSC, 32BIT, MC56F84, 100MHZ, 48LQFP
MC56F84452VLH
20955852095585
89T611889T6118
DSC, 32BIT, MC56F84, 100MHZ, 64LQFP
MC56F84540VLF
20955822095582
24W910524W9105
MC56F84553VLH
20955812095581
89T612189T6121
MC56F84565VLK
20955842095584
89T612289T6122
DSC, 32BIT, MC56F84, 100MHZ, 80LQFP
MC56F84587VLL
20955832095583
89T612589T6125
DSC, 32BIT, MC56F84, 100MHZ, 100LQFP
MC56F84766VLK
20955782095578
89T612789T6127
MC56F84789VLL
20955772095577
89T613089T6130
PC56F84763VLH
21155742115574
PC56F84786VLK
21155752115575
PC56F84789VLL
21155732115573
  • alternative_energy
  • freescale
  • freescale_mcu
  • mcu
