Robotics
Robotics
Blog Converting Arduino code to c++ code
  • Author Author: offlimits121
  • Date Created: 14 Dec 2016 5:06 PM Date Created
  • Views 3801 views
  • Comments 9 comments
  • robots
  • c++ programming
offlimits121
offlimits121
14 Dec 2016
Can anyone help me to convert my arduino code to c++ code. This is our project code for sumobot competition. Thanks
sumobot (1).txt.zip
    balearicdynamics over 9 years ago +1
    I suggest that you install AVRStudio. This is a full arduino supported environment and makes you the life extremely easy to make this porting. Take in account the following: .ino "sketches" are as a matter…
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +1
    Your arduino sketch is already C code, it just happens to have a set of libraries that hide the hardware from you and allow the code to be used with different hardware with little or no changes. So I would…
  • gadget.iom
    gadget.iom over 9 years ago in reply to androidrobo +1
    Is this related to the original discussion?
    So I would assume that you want to use a more traditional compiler like Atmel Studio that is based on Visual Studio 2015. This will still let you code the same way as a Sketch if you want, but also will allow you to create programs that will run without the boot loaders etc. There are plenty of examples along with Atmel Studio to give you a head start.
