Robotics
Robotics
Blog Converting Arduino code to c++ code
  • Author Author: offlimits121
  • Date Created: 14 Dec 2016 5:06 PM Date Created
  • Views 3803 views
  • Comments 9 comments
  • robots
  • c++ programming
offlimits121
offlimits121
14 Dec 2016
Can anyone help me to convert my arduino code to c++ code. This is our project code for sumobot competition. Thanks
sumobot (1).txt.zip
    balearicdynamics over 9 years ago +1
    I suggest that you install AVRStudio. This is a full arduino supported environment and makes you the life extremely easy to make this porting. Take in account the following: .ino "sketches" are as a matter…
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +1
    Your arduino sketch is already C code, it just happens to have a set of libraries that hide the hardware from you and allow the code to be used with different hardware with little or no changes. So I would…
  • gadget.iom
    gadget.iom over 9 years ago in reply to androidrobo +1
    Is this related to the original discussion?
    • .ino "sketches" are as a matter of fact C source files iwth some limitations
    • You can already add your own C files to a sketch, it is just the case of the Arduino libraries
    • As a initial startup after the installation of the AVRstudio and the Arduino support plugins you can barely import your original sketches in an AVRStudio project then move for the conversion (with a lot of documentation and helpful contextual hints).
    • There is a very high compatibility level between the AVRStudio and the java arduino IDE
    • The only limitation is that after a sketch has been ported inside a AVRStudio project you should have a backup because you can no longer open the .ino sketch with the Arduino IDE (but this is not your need).
    For any specific detail, just ask here.
    Note: clem57 is right with his suggestion and hte documentation link is a great compendium. The use of AVRStudio instead gives you the option to compile the code and upload to the Arduino board like before.
    Enrico
    Enrico
