Robotics
Robotics
Blog Grendel One
  • Author Author: johnfire
  • Date Created: 25 Sep 2017 5:27 PM Date Created
  • Views 2073 views
  • Comments 5 comments
  • neural network
  • customized raspberry pi
  • arduino uno
  • python 3
  • home assistant
  • remote sensors
  • artificial intelligence
  • computer speach
  • home robotics
  • machine learning
  • ai
  • power supply design
  • germany
  • ultrasonic_distance_meter
  • computer vision
  • raspi3
  • zero w
  • linux
  • java on pi
Grendel One
johnfire
johnfire
25 Sep 2017
Hi, to anyone who comes to read this. My name is Christopher Rehm and I am working on a robotics project that some of you may be interested in. basically i have built a custom cluster computer using 5 raspberry pis, which is the control system for a robot. the servos that control the robots movements are run by arduino micro controllers. I have built a website all about the project and would suggest that as first reading about the Grendel One project.  It involves hardware design, power supply, and sensor design, programming, a customized NIO message interface for Java programs to run asynchronously, machine learning and more. It's the kind of thing pretty much anyone could create for a few hundred euros, assuming they have time and interest to do so.  I invite all to have a look at the website and  continue to read the blog on the development of the project.
next post ill give a little project history...
here is the grendel site:
http://grendelone.christopherrehm.de
you can also download my working paper here, as I have attached it to this post.
imagegrendelWhitePaper.pdf
    DAB over 9 years ago +2
    Interesting project. Do you have a build out plan? What parts of the project will you complete first. How are you going to test them. How do you plan to integrate each thread as it becomes active. Just…
  • johnfire
    johnfire over 9 years ago +1
    right now im working on a power supply that can be operated by one of the pis. take a look at the paper i drew up, im going to post more fotos later. it is built up, has 5 raspberry pis, two arduinos 3…
  • johnfire
    johnfire over 9 years ago in reply to DAB +1
    basically each pi runs a control program and they are all connected with an asychronous message passing interface built in java (NIO) some of the Pis are devoted to things like processing incoming video…
  • johnfire
    right now im working on a power supply that can be operated by one of the pis. take a look at the paper i drew up, im going to post more fotos later. it is built up, has 5 raspberry pis, two arduinos 3 tb of hard disk storage. i have the java programs up and running and passing messages back and forth once i get the power supply done ill work more on the programming.
  • johnfire
