Robotics
Robotics
Blog Grendel One
  • Author Author: johnfire
  • Date Created: 25 Sep 2017 5:27 PM Date Created
  • Views 2073 views
  • Comments 5 comments
  • neural network
  • customized raspberry pi
  • arduino uno
  • python 3
  • home assistant
  • remote sensors
  • artificial intelligence
  • computer speach
  • home robotics
  • machine learning
  • ai
  • power supply design
  • germany
  • ultrasonic_distance_meter
  • computer vision
  • raspi3
  • zero w
  • linux
  • java on pi
Grendel One
johnfire
johnfire
25 Sep 2017
Hi, to anyone who comes to read this. My name is Christopher Rehm and I am working on a robotics project that some of you may be interested in. basically i have built a custom cluster computer using 5 raspberry pis, which is the control system for a robot. the servos that control the robots movements are run by arduino micro controllers. I have built a website all about the project and would suggest that as first reading about the Grendel One project.  It involves hardware design, power supply, and sensor design, programming, a customized NIO message interface for Java programs to run asynchronously, machine learning and more. It's the kind of thing pretty much anyone could create for a few hundred euros, assuming they have time and interest to do so.  I invite all to have a look at the website and  continue to read the blog on the development of the project.
next post ill give a little project history...
here is the grendel site:
http://grendelone.christopherrehm.de
you can also download my working paper here, as I have attached it to this post.
imagegrendelWhitePaper.pdf
    DAB over 9 years ago +2
    Interesting project. Do you have a build out plan? What parts of the project will you complete first. How are you going to test them. How do you plan to integrate each thread as it becomes active. Just…
  • johnfire
    johnfire over 9 years ago +1
    right now im working on a power supply that can be operated by one of the pis. take a look at the paper i drew up, im going to post more fotos later. it is built up, has 5 raspberry pis, two arduinos 3…
  • johnfire
    johnfire over 9 years ago in reply to DAB +1
    basically each pi runs a control program and they are all connected with an asychronous message passing interface built in java (NIO) some of the Pis are devoted to things like processing incoming video…
    Just curious.
  • johnfire
    basically each  pi runs a control program  and  they are all connected with an asychronous message passing interface built in java (NIO)  some of the Pis are devoted to things like processing incoming video or audio, some are structured to run general purpose machine learning algorithims on data sent by the controller. they all share a common memory space ( NFS presently) and so they can pass data simply by passing addresses on a hard drive.
  • johnfire
    DAB over 9 years ago in reply to johnfire
    Are you looking at a way to keep track of your control boards to look out for failure and to recover your status via state machine implementation?
