Robotics
Robotics
Blog Marty the pacing robot
  • Author Author: rancell
  • Date Created: 31 Jan 2019 10:13 AM Date Created
  • Views 1435 views
  • Likes 9 likes
  • stem projects
rancell
rancell
31 Jan 2019
I had worked out how to control my Marty with Scratch. But you quickly run out of dance routines to make it do. For more interesting programs, you need some input.
When you assemble your Marty it doesn't have any sensors connected to it. But the box does have two limit switches in it, and no instructions on what to do with them. I was trying to work out what to do to them (Attach them to the hands? Use them to detect when the case is open?) until I decided they would be useful to detect if Marty had walked into a wall. And then I noticed the feet had some perfectly sized holes (see below). So I guess that's what they're intended for! Using the supplied nuts and bolts they fit perfectly. I attached one to the front of the right foot and the other to the back of the left foot.
To use them I fed the connectors through a hole in the bottom of the case and attached to the GPIO connectors on "Rick" (the name of Marty's circuit board brain). Note the colours of the wires are white=IO, red=+5V, black=GND. The front switch is on GPIO 0 and the rear switch on GPIO 1.
Using the "GPIO input" blocks I wrote a simple program to make Marty walk in a direction until it hits a wall, then walk the other direction:
But it didn't work... Marty would hit the wall, and I'd see the switch trigger but it would keep walking. Then I realised it wasn't going to be quite so simple. The walk blocks take time to run so the GPIO inputs are only checked for a short time. If a switch is not being held down between the walk blocks it wont be detected. What was needed was some code to poll the switches and set some variables once they were triggered. Here is my updated program:
Works now! Here is my Marty stuck in a pacing loop (sorry Marty!):
  • 14rhb
    14rhb over 7 years ago +2
    Hi Robert, This was what I've been waiting to see, great work, thank you. Poor Marty, I hope he has found a way out of the fiendish trap Rod
    genebren over 7 years ago +2
    Great little modification to Marty. That is a pretty cool little robot. I really like his gait. Gene
  • 14rhb
    Hi Robert,
    Poor Marty, I hope he has found a way out of the fiendish trapimage
    Rod
  • 14rhb
    Hi Robert,
    Rod
