Robotics
Robotics
Forum Magnetic Sensor
  • Subscribers 75 subscribers
  • Views 773 views
Magnetic Sensor
I have a 24 vlt 2.5 amp power supply...i have the brown to 24 vlt blue to negative and i get nothing out the black wire? Help.
why is this? How and what role do these sensor play?
    Hi Nester Luis,
    It depends on the type of sensor, some sensors are digital and others are analog.
    From the digital ones you will only get a 1 or 0, which means it is either ON (0 V) or OFF(24 V).
    Depending on the sensor it can be ON when there is a metal in front of it or OFF when there is a metal in front.
    I hope that this information will help you.
    Hi Nester Luis,
    It depends which type sensor you use analog or digital. If it is an analog sensor it depends on which type output signal the sensor has voltage or amperage . Also it is very important to know  how you are measuring the output signal of the sensor.
    I hope i provide you with enough information.
    dougw over 12 years ago
    What is the part number for the sensor?
    Yes, that is correct Wesley. There are sensors that gives milliAmpere as output and there are sensors that gives Voltage as output.
    Like Douglas said, if you give the part number of the sensor we can give you more information.
