Robotics
Robotics
Forum ISO a basic robotics kit to work on with my 5yr old
  • Replies 8 replies
  • Subscribers 79 subscribers
  • Views 1033 views
danpeikes
danpeikes over 13 years ago
I had such pride the other day when my 5yr old son asked me if we could make a robot.  Does anyone have any suggestions?  Ideally something that does not call for ant soldering.  Something that starts with a basic base module that could be be expanded and accessorized later so I don't have to lay out a ton of cash to start would be a plus.  I think I would like to start with some basic motor controls and then eventually expand to adding sensors.  I looked at the stuff on Lego's site and it seems pricey.  I checked maker shed and was quickly overwhelmed by all the options.  I don't have a lot of electronics knowledge, but occasionally I like to mess around with leds, resistors, and breadboards.  I do have a degree in computer science so I am not afraid of doing a little programing if need be although I really have not written much code since college. Any and all recommendation are appreciated.  Thanks in advance.
    mcb1 over 13 years ago in reply to e14 Contributor +1
    I have a couple that I made. Both use a Tamiya dual gearbox, controller, motor driver and battery. One is simply a bump and react type which is fine for teaching actions and reactions, and working out…
  • billabott
    billabott over 13 years ago
    Since you asked,  I can strongly recommend The Hummingbird Kit from Birdbrain Tech LLC.  Visit www.hummingbirdkit.com for full info. and please tell them I sent you.
  • danpeikes
    danpeikes over 13 years ago in reply to billabott
    Looks cool but a little pricey.  Hoping to keep it under $100 to get started under 50 would be even better.
  • billabott
    billabott over 13 years ago in reply to danpeikes
    Yes, It is $200.  That's fine, just tell the kid it is too expensive to build electronics stuff that is fun.  "Sorry, Charlie."
    DAB over 13 years ago
    Hi Daniel,
    Go to the MAKE website.  They have several inexpensive kits to get you started in robotics.
    They can help you with all kinds of things for your kids age group.
    Just a thought,
  • danpeikes
    danpeikes over 13 years ago in reply to DAB
    I know there a lot of choices on Make, trying to narrow it down.
    DAB over 13 years ago in reply to danpeikes
    Hi Daniel,
    For your first robot, I would go with a simple line follower kit.  They are easy to build and would keep a 5 year old occupied just watching it follow lines around.  You could add additional sensors to it over time as your kid matures and understands what the robot is doing and would appreciate the value of the added capability.
    Keep it simple and let the kid determine when you should go the next step.
    Just a thought,
    Here's what I came across when I did a google search for robot kits:
    http://www.robotshop.com/beginner-robot-kits.html
    most if not all of these are <$100, I'm sure you could find some other sites out there with similar products.
    One is simply a bump and react type which is fine for teaching actions and reactions, and working out how to get out of a corner.
    The other is controlled by a wireless nunchuk.
    I've just purchased a zumo by Pololu which has line following or sumo capabilities.
    Its relatively inexpensive and allows different controllers to be used.
    You're quite right that you should be able to do something for $100.
    Deciding what you want the 'robot' to do is probably the first step, then deciding what kits or parts you need.
