Robotics
Robotics
Forum How to build a remote control robot
  • Subscribers 76 subscribers
  • Views 1344 views
  • robotics
  • robots
  • tft
  • control
  • lcd_display
  • robot
  • automation
  • sensor
  • robot_learning
randyskelly
randyskelly over 13 years ago
I was always been looking to build a remote control robot. Today I found this robotic car control using STM32F4 discovery broad(ARM Cortex M4)and SainSmart 3.2" TFT LCD
Anyone know how to build it? I wonder if I can use this board instead
Here is the video:
    DAB over 13 years ago +1
    Hi Randy, The short answer is that you can build an equivalent RC vehicle with a large number of different components. It all depends upon what you intend to do with it. Any basic vehicle chassis will…
    shabaz over 13 years ago
    To build it, this particular LCD display is cheaper here.
  • gihu
    gihu over 13 years ago
    Hi Randy,
    I think it is completly posible, you only have to migrate your code from stm32f407 to the stm32f107. But if you don't have the code, I strongly recommend you using just one hardware for the car, using BT instead of zigbee, and control the car from an android cell phone. I think the whole project will be easier.
    For example, using an RN42 for the BT, you will be able to configure the SPP of the BT over the air from an android phone, for example with the app BlueTerm avaliable on GooglePlay.
    Some example on youtube:
    http://www.youtube.com/watch?v=AtE86XjRM_E
    I have used before RN42 to read an 8 analog input MODBUS module from my cell phone, so, if help needed, ask me.
    Hope it helps.
    Miguel
    Hi Randy,
    Any basic vehicle chassis will work.  Any microcontroller board will work as long as it supports wifi communication and motor drives.  The main drive motor is usually DC, so you just need a good driver circuit, H-Bridge if you want to add reverse.
    Most smart phones or laptops with wifi can be used for  the touch control.
    The software is the key part.  You need to establish a protocol for the vehicle control, implement the commands and status into the vehicle microcontroller and verify that the vehicle follows the basic command set.
    Then you need to build up a GUI display for the laptop with the appropriate control threads for each of your commands.
    Verify that the laptop sends the commands correctly to the vehicle and then you are ready to play.
    The wifi might have a limited range, so you will need to put some auto-stop commands in the vehicle if it loses contact with your laptop.
    So all you need to do is get the basic components and build it all up.  It should be an easy project for anyone with experience in microcontrollers and communication skills.
    If you decide to try to build it, do a post here at Element 14.  We can watch your progress and offer you suggestions if you get stuck on any issues.
    Good luck,
