Robotics
Robotics
Forum Rotation about a pole
  • Subscribers 78 subscribers
  • Views 768 views
can u figure out how this bot rotates about the pole??
http://www.youtube.com/watch?v=GzXDz9jKeS4
    DAB over 12 years ago
    Hi Anupam,
    It appears that the rotation is done in the middle ring.
    The center pole supports the upper ring at the top and everything swings off the center ring.
    I could be wrong, but that's what it looked like to me.
    e14 Contributor over 12 years ago in reply to DAB
    might be...
    but the main question is hw is it rotating about about the pole's axis there seems to be no actuator there??
  • alamorobotics
    alamorobotics over 12 years ago
    Howdy...
    My guess is that the robot hangs from the peg on the pole and a small wheel is mounted on the center ring to swing the robot around.
    You can hear a motor run when the robot swings around.
    Nice robot...
    /Fredrik
    e14 Contributor over 12 years ago in reply to alamorobotics
    but hw will having the motor at the center rotate the bot about the pole which is some other axis??
    isn't it more likely that the lower gripper has some wheel that rotates n hence the bot rotates about the pole??
  • vsluiter
    vsluiter over 12 years ago in reply to e14 Contributor
    I see some driving belt in the lowest section, wouldn't those rub against the pole in order to rotate?
