Robotics
Robotics
Forum MULTICOPTER PLATFORM - ARDUPILOT TILT/PAN CAMERA ANTENNA CONTROL
  • Replies 7 replies
  • Subscribers 76 subscribers
  • Views 952 views
  • tarot
  • mega
  • tilt
  • ardupilot
  • rocket
  • rc
  • tilt/pan
  • multicopter
  • gimbal
  • control
  • rocketry
  • camera
  • satellite
  • brushless
  • motor
  • pan
  • antenna
domy
domy over 13 years ago
I have 3 similar projects I need help on software developpement.
The 3 projects uses same platform, Ardupilote Mega 2.6 (if someone has a better platform; welcome for suggestions!)
PROJECT 1:  POINTING ANTENNA TO SATELLITE
Hardware: 2 brussless motors like this one
- pointing a gain antenna to a GEO satellite; so the copter is able to communicate BLOS. Tolerance of the satellite is 20 degrés total.
- We shall use the GPS and compas of the Ardupilot; plus th gyros/accelerometers of control Tarot board to stabilize.
PROJECT 2:  POINTING CAMERA TO MOVING OBJECT
- pointing a camera to a rocket launch, hovering a copter close to launch pad and getting HD video of the launch. Tolerance is very tight as the rackets is up in several seconds…
The rocket will send to the Ardupilot of the copter his position (this is small very rapid rockets toys like here.
PROJECT 3:  FINS CONTROL OF ROCKET
- Using 4 servos, we shall control direction of rocket directing the fins properly.
Is any interrested in helping or developping this pieces of software?
Can be also paid for your development time.
Best regards
Domy
  • element14jamie
    element14jamie over 13 years ago
    Hello Domy,
    Welcome to the element14 Community, I will move this discussion to the Defense and Aerospace area of the Community,
    Thank you,
    Jamie
  • domy
    domy over 13 years ago in reply to element14jamie
    Thank you Jammie,
    Is this not a little bit too much for this RC project?
    Regards
    Domy
  • element14jamie
    element14jamie over 13 years ago in reply to domy
    Domy,
    I will move this to Robotics, They may be able to assist you more with this.
    Jamie
  • domy
    Thank you!
  • domy
    Hello Jamie,
    I do not know if this question is for you... About buying components through ELEMENT14, pricing is same as on regular site of Farnell for example. Should not we get a better price?
    Regards
    Domy
  • element14jamie
    Hello Domy,
    Farnell in Europe, Newark in North America, and element14 in Asia/Pacific are the Transactional websites for the element14 Community. The element14 Community links to the correct one in your region for purchasing.
    Thank you,
    Jamie
  • ravi_butani
    ravi_butani over 13 years ago
    Hi Dominique Teyssier,
    I can Help you out with codes and development of initial prototype board...
    I know programming of Gyros, Accelerometers, compass and Servos .... I know programming of PID loop also...
    I familiar with MSP430, Arduino, PSOC and LM4f120-Stellaris platforms...
    www.youtube.com/user/ravibutani03 here you can see some of my small projects....
    So I would like to work with you for your projects if further specifications will be provided by you...
    my email ID is ravi.butani@marwadieducation.edu.in
