Robotics
Robotics
Forum is there any difference between different kinds of arduino?
  • Subscribers 77 subscribers
  • Views 897 views
Hy,
I am working on Electrospinning (fiber fabrication technique). I am using Arduino 2560 and using 3 stepper motors. The gist of project is to make the whole machine setup 2D so that electrode can move in "x" as well in "y" direction.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to e14 Contributor +1
    Can you please mark as correct or helpful answer as there's a new points thing happening and im behind
    From a speed perspective they all pretty much run at 16Mhz
    What varies is the amount of RAM, FLASH Memory and IO pins. Top for IO is the ATMEGA2560 and at the bottom the ATTINY85
    For full details see the arduino site for the specefications http://www.arduino.cc/en/Main/Products
    hope this helps
    Peter
    thank you..i really appreciate your help.
    Can you please mark as correct or helpful answer as there's a new points thing happening and im behind image
    Peter Oakes (to Jaffer Niazi) 18 hours ago
    hope this helps
    Peter
    HELPFUL ANSWER
