Robotics
Robotics
Forum Labview and coordinates
  • Replies 8 replies
  • Subscribers 78 subscribers
  • Views 2116 views
  • robotics
  • robot
  • accelerometer
  • servo
  • gyroscope
  • labview
Hello, I am trying to write a code in labview to move my robots servo motors. The input i have is an accelerometer and i have x, y, z coordinates. I am trying to figure how how to convert those in degrees so the servos can understand and to get stable linear movement from all the servos at the same time.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    What is the input to the control environment from the sensor, what is the sensor, please provide link to data sheet, also a general schematic for the project and what the servos are you are using
    the sensor is the MPU-6050MPU-6050 module for arduino https://www.cdiweb.com/datasheets/invensense/MPU-6050_DataSheet_V3%204.pdf (data sheet), the servos are tower pro 946R. the arduino module has I2C interface and is connected to arduino. Everything works and I am getting coordinates in labview. I just need to translate those to degrees i guess so the robot whould move according to where the accelerometer is
  • sarunaszx
    0 sarunaszx over 10 years ago in reply to e14 Contributor
    well, thats pretty straightforward I guess.
    //  apply  trigonometry  to get the  pitch  and  roll:   pitch  =  atan(xAxis/sqrt(pow(yAxis,2) +  pow(zAxis,2)));
    roll  =  atan(yAxis/sqrt(pow(xAxis,2) +  pow(zAxis,2)));
    //convert radians  into degrees
    pitch  =  pitch  * (180.0/PI);
    roll  =  roll  * (180.0/PI)  ;
  • sarunaszx
    0 sarunaszx over 10 years ago in reply to sarunaszx
    If you want a Labview sketch, I can make a subVI later with inputs of accelerometer x,y,z data and outputs of roll and pitch (if you tell me which Labview version you are using)
    0 e14 Contributor over 10 years ago in reply to sarunaszx
    aciu sarunai
    labview 2014
  • sarunaszx
    I made a small code following the example I have given you earlier.
    https://www.dropbox.com/s/fue5amc51brprwt/AccAnglesDegrees.vi?dl=0
    Roll/Pitch directions might be different - you might need to change the sign of x,y or z. But I think you will manage it.
    thank you. I will try this and post my results later
    so I am assuming you have already looked at this but here it is incase and for others
    I have never played with this motion control stuff but do understand what you want to do, Im just not familuar with the math
    https://en.wikipedia.org/wiki/Euler_angles
    http://web.mit.edu/course/2/2.05/www/Handout/HO2.PDF
    gyroscope - MPU6050 output yaw pitch and roll with Arduino - Stack Overflow
