Robotics
Robotics
Forum Robot Trouble
  • Replies 10 replies
  • Subscribers 77 subscribers
  • Views 2349 views
Robot Trouble
hank_the_electric_explorer
hank_the_electric_explorer over 9 years ago
                    For the past few months I have been working on a robot. I need some advice to make a remote control robot. I am using a L293D as the motor driver wired to my Arduino UNO . I can not find a code for a IR remote control robot. So I was thinking. Maybe the best choice would be to use a nRF24L01? I could just wirelessly control my robot with another Arduino or raspberry PI. If you could find a code for either the nRF24L01 or a IR remote I would be much obliged.
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +1 verified
    Assuming you know how to control the Motors already (You don't say you have an issue with that), then all you need to do is adapt any of the readily available IR remote control sketches out there. The…
    Robert Peter Oakes over 9 years ago in reply to hank_the_electric_explorer +1 suggested
    Did you look at the complete IR controlled Arduino Robot I linked ?
    balearicdynamics over 9 years ago in reply to hank_the_electric_explorer +1
    The point is that you should think as two separate things. The motors should work with some commands. I suggest to develop this part first. When you are aware of all the commands you need and the motors…
    0 balearicdynamics over 9 years ago
    Hello Ben,
    I have developed a complete IR control that can be supported for Arduino too. You can find here a post explaining the controller approach: Meditech: The infrared controller
    it was developed on a Chipkit that is Arduino compatible and a Raspberry PI. If you are interested I will check the material and send it to you.
    Enrico
  • hank_the_electric_explorer
    0 hank_the_electric_explorer over 9 years ago in reply to balearicdynamics
    I need to find out how to control 2 motors
    0 Robert Peter Oakes over 9 years ago
    Assuming you know how to control the Motors already (You don't say you have an issue with that), then all you need to do is adapt any of the readily available IR remote control sketches out there. The only difference would typically be calling your movement routines instead of whatever the specific IR sample does.
    Have you tried any sample IR applications ?
    Do you have code that drives the motors already ?
    Do you understand each of the above, if so then try to adapt them and combine into one app. Show us what you have and well help you with issues,
    Also, even a trivial google search for "  arduino ir remote control robot " takes me immediately to this and even uses the same motor driver chip
    ARDUINO based IR remote control robot
    It's the very first answer !.
    Everyone here is happy to help but please help yourself first with a little research at least !!.
    0 hank_the_electric_explorer over 9 years ago in reply to Robert Peter Oakes
                             Dear Peter. I have found out how to control the motors with a L293D. I need help with making it remote controlled. I found a code but it wont work the motors wont spin or anything. it has a big power supply and everything I need help with the programming. I am not the best programmer. So I have found the IR Remote Lib for the Arduino IDE, but when I uploaded the code, the Arduino ran the code but the motors did not spin when I pressed the button. I will check the wiring again. image
    0 hank_the_electric_explorer over 9 years ago in reply to hank_the_electric_explorer
    with a remote (by the way)
    0 Robert Peter Oakes over 9 years ago in reply to hank_the_electric_explorer
    0 balearicdynamics over 9 years ago in reply to hank_the_electric_explorer
    The point is that you should think as two separate things. The motors should work with some commands. I suggest to develop this part first. When you are aware of all the commands you need and the motors works fine, at this point you can implement the second part, sending commands via IR.
    Enrico
    I have looked at it I believe it is the same program I am using but I will make sure. Thank you very much
    imageimageI Found I missed a step So Thank you very very muchimageimage
    Hello Ben,
    Me too I started from the Arduino library for IR control; I suggested my previous project just because this library in my opinion is redundant and not well explained. And has some issues that makes it not working or anyway not easy to understand.
    Enrico
