Robotics
Robotics
Forum Lidar Lite v3 Irratic Measurement
  • Replies 12 replies
  • Answers 7 answers
  • Subscribers 77 subscribers
  • Views 3770 views
  • lidar
  • garmin
brucewilsonph@yahoo.com.ph
brucewilsonph@yahoo.com.ph over 8 years ago
Hello Everyone!
I have a Garmin Lidar Lite v3.
There is an obstacle at 24" in from of the Lidar.  About one percent of the time, the Lidar will give a measurement of about 14" or about 9".
What could possibly be happening?
Bruce
  • the48sicks
    the48sicks over 8 years ago +1 suggested
    Hi Bruce Mine does exactly the same, I think Douglas and DAB have it thouh. You can try setting the different modes for short/mid/long range to make it a bit more accurate. In the end I started taking…
  • the48sicks
    the48sicks over 8 years ago in reply to brucewilsonph@yahoo.com.ph +1 suggested
    Hi Bruce Im using the LIDARLite Arduino Library. It gives you options for config and scanning. When you call the distance method there is also a true/false parameter to scan with or without bias correction…
  • brucewilsonph@yahoo.com.ph
    brucewilsonph@yahoo.com.ph over 8 years ago in reply to the48sicks +1
    That information isn't in the Python library. Thank you so much!
    0 brucewilsonph@yahoo.com.ph over 8 years ago in reply to the48sicks
    For any Python users out there, you may find a configure method in my LidarLite3Ext class.
    It can be found at https://github.com/Z223I/LidarLite3Ext
    The Extension class also contains methods for threading.  It is a producer/consumer model using the Python thread safe queue class.
    Best wishes!
    Bruce
    No. I am not doing point clouds.  It does sound interesting.
    Thank you everyone for your help!  My robot works SO MUCH BETTER now.
