Robotics
Robotics
Forum Lidar Lite v3 Irratic Measurement
  • Replies 12 replies
  • Answers 7 answers
  • Subscribers 77 subscribers
  • Views 3697 views
  • lidar
  • garmin
brucewilsonph@yahoo.com.ph
brucewilsonph@yahoo.com.ph over 8 years ago
Hello Everyone!
I have a Garmin Lidar Lite v3.
There is an obstacle at 24" in from of the Lidar.  About one percent of the time, the Lidar will give a measurement of about 14" or about 9".
What could possibly be happening?
Bruce
  • the48sicks
    the48sicks over 8 years ago +1 suggested
    Hi Bruce Mine does exactly the same, I think Douglas and DAB have it thouh. You can try setting the different modes for short/mid/long range to make it a bit more accurate. In the end I started taking…
  • the48sicks
    the48sicks over 8 years ago in reply to brucewilsonph@yahoo.com.ph +1 suggested
    Hi Bruce Im using the LIDARLite Arduino Library. It gives you options for config and scanning. When you call the distance method there is also a true/false parameter to scan with or without bias correction…
  • brucewilsonph@yahoo.com.ph
    brucewilsonph@yahoo.com.ph over 8 years ago in reply to the48sicks +1
    That information isn't in the Python library. Thank you so much!
    0 DAB over 8 years ago
    You could be getting reflections from more distant objects that are appearing in the next distance cycle.
    It depends upon the AGC they use and the chirp encoding.
    Given the price of the unit, I would expect it to have just minimal interference circuitry built in, so you will expect to see some erratic behavior.
    Is there a highly reflective target in the far field?
    Different reflectivity can introduce errors.
    0 dougw over 8 years ago
    Is it possible it is seeing some dust? You could try sprinkling some dust in the beam to see how much it takes to start getting erroneous data.
  • the48sicks
    0 the48sicks over 8 years ago
    Hi Bruce
    In the end I started taking 3 measurements and taking an average of the closest 2 results. Increases the scan time though so its not really ideal but it smooths things out a bit
    0 brucewilsonph@yahoo.com.ph over 8 years ago in reply to the48sicks
    Will check to see how to control the ranges unless you post it here first.  :0
    0 brucewilsonph@yahoo.com.ph over 8 years ago in reply to DAB
    Thank you so very much!  Will have to remember this when I get it into a real working environment.
    Here is the document that I am using:  https://static.garmin.com/pumac/LIDAR_Lite_v3_Operation_Manual_and_Technical_Specifications.pdf
    Is it the same document that you are using?
    Apparently I am overlooking the close, mid and long range setting if it is.
    Bruce
  • the48sicks
    0 the48sicks over 8 years ago in reply to brucewilsonph@yahoo.com.ph
    Hi Bruce
    When you call the distance method there is also a true/false parameter to scan with or without bias correction. Its recommended to run this every 100 scans or so
    https://github.com/garmin/LIDARLite_v3_Arduino_Library/archive/master.zip
      Parameters
      configuration:  Default 0.
        0: Default mode, balanced performance.
        1: Short range, high speed. Uses 0x1d maximum acquisition count.
        2: Default range, higher speed short range. Turns on quick termination
            detection for faster measurements at short range (with decreased
            accuracy)
        3: Maximum range. Uses 0xff maximum acquisition count.
        4: High sensitivity detection. Overrides default valid measurement detection
            algorithm, and uses a threshold value for high sensitivity and noise.
        5: Low sensitivity detection. Overrides default valid measurement detection
            algorithm, and uses a threshold value for low sensitivity and noise.
      lidarliteAddress: Default 0x62. Fill in new address here if changed. See
        operating manual for instructions.
    Hope this helps! Any questions please dont hesitate to ask
    Matt
    Thank you so much!
    Every 100 scans or so, am I to run read with what option?  W/o bias correction?
    I have translated the CPP configuration method to Python.
  • the48sicks
    Nice work!
    Its on by default, so you can run the method sending false as an argument, then every 100 add a true in there
    Looking at the comments on the method from the .cpp file
      biasCorrection: Default true. Take aquisition with receiver bias
        correction. If set to false measurements will be faster. Receiver bias
        correction must be performed periodically. (e.g. 1 out of every 100
        readings).
    Are you doing point clouds with your scanner?
