Robotics
Robotics
Forum Rugged multiway connector family - IDC & PCB/Panel mounting?
  • Subscribers 77 subscribers
  • Views 456 views
Hello all,
I have been trying to find a suitable family of connectors for my current design. I need to connect a control box to another piece of kit a couple of meters away in a factory/production environment. Factory operatives will be required to change which piece of kit that is connected to the control box from time to time, maybe average once a week. The following features are desired:-
  • Carry 20 or so digital signals - highest frequencie just a few kHz - signals are all 12V sub 1A
  • Right angle PCB mounting version that fits to enclosure panel and has some kind of robust quick retaining mechanism for the attached cable. (Quick meaning not fiddly screws)
  • Panel mounted version to wire wrap or similar and has some kind of robust quick retaining mechanism for the attached cable. (Quick meaning not fiddly screws)
  • Off the shelf 2m or so cable assemly to match, or IDC versions of connector for quick easy cable assembly build
D-Type connectors have already been ruled out due to fragility of pins and fiddly screw locking which the end users are unlikely to bother utilising properly. I'm getting some 'centronics' connectors to try but aren't so sure that the retaining clips will be robust enough.
Does anyone out there have any good ideas for this? It seems like a pretty normal requirement and like I must be missing the obvious!
many thanks,
  • lpetacchi
    0 lpetacchi over 15 years ago
    usually control boxes are connected to "satellite" equipment via serial interfaces, like RS485 or similar. This allows low pin count connections, with simpler and more economical connectors.
    Circular connectors could be a good fit for your requirements; for example Hirose HR25 (do you need IP rating ?).
    Another solution could be an automotive connector like Hirose GT17.
    Have a look also at Samtec range of products.
    bye
    0 e14 Contributor over 15 years ago
    Is request stil valid.
    If so i might be able to help you.
    Jus let me know.
    Best regards,
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    The 'Centronics" type connectors proved to be acceptable in this  application. But I'm sure we would all like to hear you thoughts anyway.  What alternative can you suggest? It may help someone else.
