Robotics
Robotics
Forum Servo trouble
  • Replies 52 replies
  • Subscribers 67 subscribers
  • Views 6857 views
Servo trouble
royston02
royston02 over 11 years ago
I wanted to know if a servo left without power in stationery mode (without making me want to turn it) lift the weight?
Eg:- A skateboard. I just want to stand on itwithout it moving. the skateboard is the servo. Will the skateboard i.e servo stand or fall? No battery.
    dougw over 11 years ago +2
    If you can live with a normal DC motor and use it with a worm gear, it should "lock" when not powered.
    mcb1 over 11 years ago in reply to royston02 +1
    Try this .. Open your browse and enter this in a google search "how does a servo work" the first two results give a good breakdown of how it works. Mark
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    Note there are many different systems that fall under the name of SERVO. The one you linked in may be geared but not like the one shown above. A typical Remote control plane/Car/Boat servo is based on…
  • royston02
    0 royston02 over 11 years ago in reply to dougw
    Alright. many of you are getting confused with transportation jet idea.
    Eg:(took me a long time to think)
    Suppose I was making a robot like a human on wheels and want it to carry weight on the back.I made a rectangular box for it. If I directly mount it on the back of the robot to things:-
    a)It will not have a proper centre of gravity.
    b)It will strain the motors.
    So I thought to use a servo. Servo will drain the battery and I am not moving it. the arm wll be stationery. SO I thought about not powering the servo.
    Will the servo hold the weight the weight without power?
    And I am not using a gas turbine engine because I wanted it to be a green project.
    0 Robert Peter Oakes over 11 years ago in reply to royston02
    A diagram will really help for us to visualize what your really trying to build, even if it is a straw man type diagram
    Are you trying to make a humanoid like robot on wheels where you want to carry a load on its back ??, and is the plan to use a motor or servo (By the way there both motors and while in motion will consume similar amounts of energy as this is proportional to the work it has to do) to lift a load into place on the back of said humanoid robot
    you could use a clamp to hold the load when it gets there,
    as I said, a picture will help unbelievably in clarifying what your really trying to achieve as "suppose" statements makes us think you not sure.
    Were not trying to be awkward, just your being a little vague
    Please post a picture ?
  • dragonstyne
    0 dragonstyne over 11 years ago in reply to royston02
    Royston,  thank you for your explanation.  As Peter said, a diagram would help greatly. Based on what you have given us so far:
    I agree a winch servo or a servo modified for continuous movement passed 360 degrees, is the best choice for your project.  However,  it will not hold a load reliability without power.
    You may need something in the box the passivity hood the load during transport. Or a transmission with a worm drive or brake to hold the load.
    A diagram will confirm this.
    -Steve
  • royston02
    0 royston02 over 11 years ago in reply to dragonstyne
    http://www.ez-robot.com/Shop/Images/Products/1355/Adapter%20with%20servo.jpg
    http://www.ez-robot.com/Shop/Images/Products/1355-hd.jpg
    Had problems sving a image to the discussion so had to find a similar one/s. Hope you copperate. The fomer one is like the servo clipped to the latter one. The fomer's part clips to the humanoid.(sorry for the lame explanation).The latter will be the rectangular one with the box. Only a different. Once I figure a way to upload picture I will try to.
  • dragonstyne
  • royston02
    Goes to a whole new page and in the url shows the file location and displays the picture. What next?
  • dragonstyne
    Select the picture and press "Insert Picture" lower right side of the pop up.
  • royston02
    http://img.deusm.com/eetimes/2013/10/1319757/max-0087-03.jpg
    In this, the top part is what I want to hold heavy object. I want to use servo under the lower frame to hold the top one. If I don't power the servo, will the frame hold or servo fail? I don't want to load or anything. Just hold the weight on the servo without power.
    Can someone make a tutorial for loading custom pictures. My dosen't load.
    0 dougw over 11 years ago in reply to royston02
    Hi Royston,
    Will the servo be used to tip load bed like a dump truck?
    If I understand it...
    When the load bed is flat and inactive, it could simply rest on fixed "stop" posts, taking the load off the servo.
    When the servo needs to move the load bed, the load bed would simply lift off the stop post(s) and hinge up.
  • royston02
    The servo is stationery, no tipping, no loading. The thing is that I'm using it to hold load since the motors are brushed. Yo the servo will be kept underneath and I want the servo to carry the weight without transferring to the load to the motors/frame(since all the weight is absorbed by the gears). You all are a long way from my point I've noticed.I prefer you ask everything to clear your mind to the point.
