Robotics
Robotics
Forum Led help?
  • Replies 14 replies
  • Subscribers 80 subscribers
  • Views 2097 views
Led help?
bradnorwood
bradnorwood over 11 years ago
I have a simple project I need help with. It's a dual 10 LED light which hangs from my glasses to light the area I'm working on. It's nothing major but, I'm good at 3d printing but know very little in electronics. They are 3 mm LED's 3.2 volts 20 ma. Can someone help me with wiring this to an easy battery pack that I can attached to my belt etc. It needs to power 20 of them and last for 2-4 hours maybe. thx!
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to timswift +2
    keep it up, I like your approach, just trying to help you get it right without doing it for you , I would do the same to my own son as it helps in the learning and your learning nicely regards Peter
  • johnbeetem
    johnbeetem over 11 years ago +2
    A very efficient way to drive a bunch of LEDs is to connect them in series and use a DC-to-DC switching regulator to raise your battery voltage up to whatever is needed to provide a given current for the…
    Robert Peter Oakes over 11 years ago in reply to johnbeetem +2
    What he said, the more in series the more efficient (And less components)
  • bradnorwood
    0 bradnorwood over 11 years ago
    Thx! That's awesome!
  • bradnorwood
    I like this but it's in series, and I'm kinda wanting to parallel this project being the LED's are so close, do you have software that figured this out or access to a library that had this? Thx
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to bradnorwood
    I've already got the positives on the inside and neg on the outside
  • bradnorwood
  • timswift
    0 timswift over 11 years ago in reply to bradnorwood
    The schematic is in parallel.
    Did you 3D print the mounts?
    Tim
    0 Robert Peter Oakes over 11 years ago
    Hi there Tim
    You need limiting resistors in series with the LEDs, if you turned this on will a charged LION battery you would fry all the LEDs due to excessive current
    Charged LIPO is about 4.2V, a small series resistor for each LED of about 50 ohms would limit the current to 20mA when fully charged and a bit less as the battery discharges, a more efficient way would be to boost the voltage to say 16V and put the LEDs into groups of 5 in series, with a small 50R resistor , this overall would be more efficient
    Either way you absolutely should put in current limiting resistors
    and remember this is a LIPO, ensure it has protection circuitry built in or be aware of the discharge as you can damage the batter or worse if you dont treat it nicely
    Regards
    Peter
  • timswift
    0 timswift over 11 years ago in reply to Robert Peter Oakes
    Thanks Peter
    I new i forgot something!
    I will update the the schematic.
    Tim
  • timswift
    Here is the updated schematic:
    0 Robert Peter Oakes over 11 years ago in reply to timswift
    resistor for EACH led image, not just one at the beginning or one for the whole chain, LEDs have a habit of hogging the current otherwise as there not all identical and the one with the lowest Von will hog the current, also each pair of LEDs is not joined to the next, except for the first 10 to second 10
    keep it up, I like your approach, just trying to help you get it right without doing it for you image, I would do the same to my own son as it helps in the learning and your learning nicely
    regards
    Peter
