Robotics
Robotics
Forum Led help?
  • Replies 14 replies
  • Subscribers 80 subscribers
  • Views 2098 views
Led help?
bradnorwood
bradnorwood over 11 years ago
I have a simple project I need help with. It's a dual 10 LED light which hangs from my glasses to light the area I'm working on. It's nothing major but, I'm good at 3d printing but know very little in electronics. They are 3 mm LED's 3.2 volts 20 ma. Can someone help me with wiring this to an easy battery pack that I can attached to my belt etc. It needs to power 20 of them and last for 2-4 hours maybe. thx!
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to timswift +2
    keep it up, I like your approach, just trying to help you get it right without doing it for you , I would do the same to my own son as it helps in the learning and your learning nicely regards Peter
  • johnbeetem
    johnbeetem over 11 years ago +2
    A very efficient way to drive a bunch of LEDs is to connect them in series and use a DC-to-DC switching regulator to raise your battery voltage up to whatever is needed to provide a given current for the…
    Robert Peter Oakes over 11 years ago in reply to johnbeetem +2
    What he said, the more in series the more efficient (And less components)
  • johnbeetem
    0 johnbeetem over 11 years ago
    A very efficient way to drive a bunch of LEDs is to connect them in series and use a DC-to-DC switching regulator to raise your battery voltage up to whatever is needed to provide a given current for the LEDs.
    Linear Technology and (I think) TI have suitable parts.  Here's a part from Linear Tech as a starting point to give you an idea how to do this: http://www.linear.com/product/LT1618
  • dwinhold
    0 dwinhold over 11 years ago in reply to timswift
    Another quick way to save a bit of time is to put all the negative's of the LED's in the negative rail on the bread board. Put the negative leed of the battery in that rail, put the positive of the battery in the positive rail, join the positive rail to each of the positives on the LED's with a resistor.
    Dale
  • timswift
    0 timswift over 11 years ago in reply to dwinhold
    I like that ideaimage.
    Tim
    0 Robert Peter Oakes over 11 years ago in reply to johnbeetem
