Robotics
Robotics
Forum H Bridge for Sewing Machine
  • Answers 2 answers
  • Subscribers 78 subscribers
  • Views 844 views
  • sewing_machine
  • h-bridge
  • dc_motor
binarygenius
binarygenius over 11 years ago
Hi i am looking for a H bridge design that could power a 24v 5A 120w DC Scooter motor that i will be using on an old sewing machine. i will be controlling it with an arduino and it will be stopping starting and reversing a lot so any advice would be welcome. i have both P and N channel fets in my bits box mostly TIP and IRLZ44N and a ton of BUS12 NPN 8A 400V if that helps.
Many Thanks Mick
  • D_Hersey
    D_Hersey over 11 years ago +1 suggested
    The bane of the H-driver is punch-through. This is when a non-adjacent pull-up and a pull down open with no current limit because the load isn't in the current path. Careful timing can avoid this. Putting…
    0 jw0752 over 11 years ago
    Hi Mick, I don't know if you have the book "Practical Electronics for Inventors" 3rd Edition by Paul Scherz and Simon Monk but on page 916 there are two circuits for H-Bridges using Darlingtons in one case and MosFets in another. You might also find that you can get an H-Bridge on a single chip that can handle that much current if properly heat sunk.
  • binarygenius
    0 binarygenius over 11 years ago in reply to jw0752
    Thank you so much after reading a few reviews of  Practical Electronics for Inventors and getting a lets say a preview digital copy of the book i have just ordered the paperback from amazon, What a book i have been looking for something like it for years and after waiting forever for the newest version of the art of electronics to be released this book looks like the perfect addition to my bench.
    Mick
  • D_Hersey
    0 D_Hersey over 11 years ago
    The bane of the H-driver is punch-through.  This is when a non-adjacent pull-up and a pull down open with no current limit because the load isn't in the current path.  Careful timing can avoid this.  Putting a current sink below the H drive solves this.  Using a split supply and two transistors solves this.
