Robotics
Robotics
Forum Allegro A3941 full bridge mosfet driver
  • Subscribers 77 subscribers
  • Views 1592 views
GP100
GP100 over 11 years ago
Has any one had experience with this device. Looking for some good application circuits. Allegro web site is a bit lacking.
    0 michaelkellett over 11 years ago
    That's a great data sheet - you won't find better !
    If you need to learn about driving MOSFETs then Google a bit more widely than just the A3941. What's your application ?
  • GP100
    0 GP100 over 11 years ago
    Agreed the data sheet is quite comprehensive just would be good to have a little bit more on the application side.
    It's a 12v DC Motor in an automotive application.
    The H bridge circuit is not a major issue it's the Boot strap charge I am having problems with. We need to be running at approx 15Khz
    0 michaelkellett over 11 years ago in reply to GP100
    What's the problem - understanding how it works or calculating the capacitor values ?
  • GP100
    0 GP100 over 11 years ago in reply to michaelkellett
    Not a hundred percent sure!
    It may be I have calculated the value incorrectly or have other issues.
    It seems to be OK at lower frequency's (up to approx 5Khz) but the bootstrap voltage drops when running at 15Khz and hence affects the bridge operation.
    Now back to work so will be wiring up the error pins to see if this sheds more light on it
    No
