Sensors
Sensors
Blog Building the impedance measurement circuit
  • Author Author: Zainii
  • Date Created: 10 Aug 2024 1:32 AM Date Created
  • Views 1900 views
  • research
  • sensing
  • detection
  • Design
Zainii
Zainii
10 Aug 2024
Dear Members,
I hope you are all doing well.
I am a PhD student and completely new to circuit design. I need a compact-sized circuit and prefer not to use an impedance analyzer due to its bulkiness. I am looking to build a circuit capable of automatically measuring the impedance of a sensor in the range of 1MΩ to 30MΩ. However, I am unsure how to approach this task, especially with the various methods available for impedance measurement. I’m not certain which method would be most suitable for automatic measurement in my case. There are different impedance measurement modules, but none seem to have the capability to measure impedance automatically within this range. My sensor’s equivalent circuit is a resistor in parallel with a capacitor.
Could someone guide me through the procedure to build the circuit design? Specifically, I would like to know which components I should purchase to begin building the circuit. If there are any tutorials or resources that you could recommend, that would be very helpful as well.
So far, I have only completed the integration of a DDS (Direct Digital Synthesis) with an Arduino to generate a signal with a frequency of 1 kHz and an amplitude of 500mV, which meets my signal requirements. However, I am uncertain about how to proceed with the remaining circuit design.
Your help in this matter would be greatly appreciated.
    shabaz over 2 years ago +2
    This is non-trivial, not sure how you expect to design and build this if you're completely new to circuit design! You could buy your way out of the problem, there are LCR modules that support the measurement…
  • dang74
    dang74 over 2 years ago
    You could maybe use the DDS to sweep frequency.  Then attach a resistor in series between the DDS output and your sensor and observe on an oscilloscope. At lower frequencies the series resistor and sensor would form a voltage divider.  So you will be able to determine the sensor's resistance.  Somewhere in the sweep the amplitude will reach a peak.  This is the resonant frequency.  With the series resistor, sensor resistance and resonant frequency all being known at this point, you can determine the capacitance.  If I am not mistaken at resonance the series resistor will be equal to the parallel combination of the sensor resistance and capacitor reactance.  So use that as the basis to figure out the capacitance.
  • dang74
