Sensors
Sensors
Blog Inductive Sensing Design Challenge - ISDC
  • Author Author: COMPACT
  • Date Created: 21 Apr 2014 7:07 PM Date Created
  • Views 467 views
  • inductive_sensing_challenge
  • inductive_sensor
COMPACT
COMPACT
21 Apr 2014
Hi Everyone,
I purchased an LDC1000 when it was first released to evaluate it.
It is capable of detecting sub micron distances. That's really impressive!
And can be used for axial distance measurement, linear position measurement and angular position measurement.
It has also won many accolades including EDN Hot 100 (2014), Electronik Active Component Rank #1(2014), EE Times ACE award (2014) and Best Electronic Design (2013)
It affordable with an approximate price of $2.95 in 1k quantities
Like most sensors these days have been made easy to interface with a serial interface and the LDC1000 is no different. The LDC1000 has a SPI interface.
It also has an dedicated Interrupt signal that can be asserted should threshold values be exceeded.
It has a wide I/O voltage range from 1.8 to 5 volts and requires a 5 volt analog power supply.
Being an inductive sensor a sense coil is required. Its response is dependent upon the sensor's target.
Very Compact
    DAB over 12 years ago
    Hi Monte,
    I did the same thing.  The device is amazing in sensitivity and versatility.
    TI has several excellent videos showing you how to modify the basic kit to approach more practical problems for inductive sensing.
    The output is easy to capture and post process.
    I just wish I had more time to play with it.
    Hi Monte,
