Sensors
Sensors
Blog Inductive sensing design challenge: Heamoglobin level sensing.
  • Author Author: arunmagesh
  • Date Created: 11 May 2014 3:00 PM Date Created
  • Views 1928 views
  • Comments 10 comments
  • inductive_sensing_challenge
arunmagesh
arunmagesh
11 May 2014
Hello! Good day!
Before i start let me thank element14, texas instrument, cadsoft for selecting my idea and sponsoring my
project idea,
Let me break my crazy little idea i wish to do with Inductive sensor. Is measuring haemoglobin level in our
blood using this touchless Inductive sensor. As you all know our blood is made of iron. So i consider that
as conducting material. Now inorder to get something from it. I first give a magnetic flux/filed to a
specific part of our body say finger. Now due to mutual induction some field is developed in our blood
which will be soo tiny. Which is recorded by the sensor, based on continous sampling and leveling. And
haemoglobinlevel can be ccalculated by converting ginduction into density by some formula( i have to
refer some books). And we can get haemoglobin level.
Now i need experts and noobs to help me accomplish it.
Thank you.
M.Arun Magesh
    DAB over 12 years ago +3
    Interesting idea. You might want to experiment with something like ferric chloride to see at what PPM you can detect the iron in solution. You also might consider how salt and other body minerals in the…
  • waelect
    waelect over 12 years ago +1
    I am not sure if this will help, but just in case the measurement could include other tissue, bone or other. Consider directing or blocking inductive sensing to cover only a small portion of the targeted…
    e14 Contributor over 12 years ago in reply to waelect +1
    I agree. Instead of the default PCB coil you can use a smaller coil with a ferrite shield. The target area will be much smaller. What kind of display do you need to show the reading?
    Interesting idea.
    You also might consider how salt and other body minerals in the blood will influence the results.
    I had an idea similar to this but I just never had the time to do the work.
    Interesting idea.
  • arunmagesh
    arunmagesh over 12 years ago in reply to DAB
    That's good idea for testing so i don't have to spill my blood..
