Sensors
Sensors
Blog Interfacing PIR sensor to Thunderboard sense 2
  • Author Author: Haythem
  • Date Created: 13 Apr 2022 8:22 PM Date Created
  • Views 1142 views
Haythem
Haythem
13 Apr 2022
Hello everyone, this is my first time posting in the forum.
So i am working with thunderboard sense 2 and simplicty studio. I want to use an external PIR sensor connected to the board to get PIR data in my PC. As in read the analog PIN and value and see it in my pc.
Then i have to make this connection through bluetooth. Create a service/client with GATT configurator so that i can connect to my thunderboard with bluetooth and see the PIR data. I am very new to all of this. So it will be very helpful if you helped me even with a little code that i can run in simplicty studio so that i can read analog values of PIR sensor. This is very important for my project. Thank you all.
  • BigG
    BigG over 4 years ago
    Unfortunately, there are no short cuts to learning... I suggest following the guidance given in Simplicity Studio when you plug in your Thunderboard 2 board... I believe they provide a quick start guide, which gives a great overview and provides links to explaining the Bluetooth stack etc. Understand this document and you are well on your way.
    https://www.silabs.com/documents/public/quick-start-guides/qsg169-bluetooth-sdk-v3x-quick-start-guide.pdf
    The only tip I can think of at this stage, is that as the values read from your analog pin can be larger than a byte, you will need to choose a characteristic type that matches your data type. In this case you could choose "short" or "integer" to handle the data transfer.
  • BigG
