Sensors
Sensors
Blog NASA and the NOAA Measure the Ozone Hole Over Antarctica
  • Date Created: 24 Nov 2026 11:00 AM Date Created
  • Views 14 views
  • environment
  • nasa
  • environmental sensor
  • sensor
  • ozone
24 Nov 2026
Visual of the ozone hole’s area and shape on September 18, 2026. (Image Credit: NASA Earth Observatory/Lauren Dauphin)
Earlier, NASA and the NOAA reported that the Antarctic ozone hole is unusually large this year. Their conclusion didn’t come from just a satellite image. Weather balloons launched from the South Pole and a ground-based instrument that monitored the ozone for decades helped with those measurements. With these techniques, scientists figured out the size of the ozone hole and how deeply it depleted above Antarctica.
Satellites measure the size of the hole. Specifically, it comes from NASA’s Aura (OMI instrument), NOAA-20, NOAA-21, and the NASA-NOAA Suomi NPP satellite. From polar orbits, these monitor the atmosphere by scanning the area above Antarctica. Their job is to measure UV radiation and signals affected by the ozone. Since the ozone absorbs certain UV light wavelengths, researchers can rely on these observations to predict how much ozone exists through a vertical air column.
This produces a daily map of total-column ozone. Scientists then find regions where the ozone falls under 220 Dobson units. This measurement was used by NASA and NOAA to determine that the 2026 hole averaged 9.6 million square miles between September 7th and October 13th. On September 18th, it reached 10.5 million square miles.
While satellite imagery shows the ozone hole’s extent, there is less detail regarding how the ozone spreads at varying heights. NOAA uses balloons launched from the South Pole Baseline Atmospheric Observatory. The balloons are equipped with an ozonesonde. This small instrument measures ozone concentration while ascending. The sensor records ozone levels at various altitudes and creates a vertical profile. Those measurements show the severity of conditions over the South Pole. Around October 17th, the ozone lowered to 105 Dobson units, the lowest in 2026.
A Dobson Ozone-Spectrophotometer is being used at the South Pole as well. This instrument points upward to measure the intensity of certain UV wavelengths in sunlight that reach the ground. Since UV radiation is absorbed by the ozone at certain wavelengths, scientists can calculate the total ozone by comparing the measurements with satellite data. The Spectrophotometer also retains historical data. So, it can track changes in the ozone over time.
Scientists used these measurements to explain the huge hole. A powerful polar vortex trapped cold air over Antarctica, which led to conditions that favor ozone-destroying chemical reactions. The vortex kept its size due to weak planetary-scale weather waves in August and September. This meant ozone-depleting chemistry could continue.
According to NOAA and NASA, the hole doesn’t mean the ozone layer won’t recover. Fewer ozone-depleting chemicals ensured conditions wouldn’t worsen. And the ozone layer is expected to keep recovering in the upcoming decades.
