Sensors
Sensors
Blog Researchers Unlock a 400-Year-Old Artifact Lock
  • Date Created: 20 Nov 2026 10:00 AM Date Created
  • Views 22 views
  • Amgueddfa Cymru
  • on_campus
  • ct
  • CT scan
  • university
  • mystery
  • Cardiff University
  • sensor
20 Nov 2026
The lock recovered from a shipwreck. (Video Credit: Amgueddfa Cymru)
Cardiff University and Amgueddfa Cymru – Museum Wales researchers unlocked a 400-year-old brass combination lock recovered from the Ann Francis shipwreck off the Welsh coast. They used micro-computed tomography (micro-CT) scanning to look at the lock’s internal components without damaging it. Eventually, the scans revealed the combination.
The museum asked Cardiff University for help unlocking the artifact, as there are 1,296 possible combinations. That’s where micro-CT scanning came into play. It relies on X-rays to take images of the lock at different angles. Once that’s done, a computer processes the measurements to replicate cross-sectional images and a 3D visual of the internal structure.
Even small features inside the lock are revealed without needing to open or dismantle it. This technique is practical as it preserves the lock’s original condition. The team also used micro-CT scanning to see if they could determine how the internal mechanism worked. First, they scanned the lock to see if there were useful details worth capturing. After the first scan, the team saw some letters within the lock. The next scan didn’t work out as they expected, so they tried again using a different technique.
In the third scan, they could see the mechanism more clearly. With this clarity, they investigated the rotating rings’ notches and how they aligned with the internal mechanism’s teeth. These alignments made it possible to determine the letters that need to line up to release the lock. Once they examined the scans for several days, the team found the combination: ANCE. Museum specialists were then handed the discovery, and they tested the combination by putting the rings into position.
“We normally use this technology to study bones and other biological structures, so investigating a 400-year-old padlock was certainly a first for us. I had to wait until later that evening for the museum team to test the combination, so getting the message that we'd cracked it was incredibly satisfying,” said Dr. David Williams, Post-Doctoral Research Assistant.
The team noticed the rings were looser during combination testing. Grit, which had accumulated, was removed from the mechanism by conservators. Cleaning it this way made it easier for the artifact to unlock for the first time in over 400 years. Researchers aren’t sure why the combination choice is ANCE, which is another mystery of the shipwreck that has yet to be resolved.
