Sensors
Sensors
Sensor Forum Do you have a question on MEMS Sensors? Ask our Expert, Donna Sandfox
  • Replies 73 replies
  • Subscribers 354 subscribers
  • Views 9847 views
  • products
  • Mechanical
  • components
  • photomicrosensors
  • sensors
  • expert
  • support
  • omron
  • mems
  • engineering
  • rf
  • switch
  • answers
  • mass_flow
  • vibration
  • question
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Sensors in the element14 Community Sensors group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Donna Sandfox
Donna Sandfox is the Product Manager for Sensors and MEMS Products for Omron Electronic Components LLC.  Her primary area of expertise is in MEMS Mass Flow Sensors.  She also supports Omron’s pressure, thermal IR, tilt/vibration and optical (photomicrosensors) sensors, as well as their RF MEMS Switch products.  Donna received her bachelor’s degree in mechanical engineering from Southern Illinois University and an MBA from Roosevelt University.
    e14 Contributor over 15 years ago in reply to DAB +1
    Hi Don! Thank you, and thanks for the question. While volumes can be written comparing and contrasting all of the different technologies available for measuring gas flow, I'll try to give a reasonably…
    e14 Contributor over 12 years ago in reply to vsluiter +1
    Hello, Thanks for your reply. The problem has now been solved. There was an error in the catalogue which has now been corrected. The correct sensors are with me and ready for test in my project. Thanks…
    e14 Contributor over 12 years ago in reply to michaelkellett
    Hi Michael - We're currently updating our site and will launch the new one with information about our 4M sensors very soon. 4M uses MEMS technology. Here are the tech specs. What kind of project are you working on?
    michaelkellett over 12 years ago in reply to e14 Contributor
    I'm not currently working on a sensor type project but I've designed accelerometers and microphones (amongst others) in the past so I'm always interested in what's going on. Are you really developing your own MEMS sensor or buying one in and packaging/conditioning it ?
    We found three 3-axis MEMS sensors that were already out there and repackaged them into a plug and play system. Our goal is to make it as easy as possible to integrate 3D motion tracking and sensing into projects. Would love to hear more about your work!
  • robdugas
    robdugas over 12 years ago
    Hi Donna,
    I'm looking for some type of low power and highly sensitive sensor to measure atmospheric pressure between two rooms such as isolation rooms in hospitals.
    Also, a sensor that can monitor air flow inside a duct system to let me know when to add or reduce air to control pressure difference between two rooms.
    I would prefer something without the use of tubing. Thank you.
    Here's a link to our 4M pre-campaign, which includes more details and visuals. Follow to stay up on the latest! http://bit.ly/1bkpJtF
    Hello Donna,
    Just to let you know you have a problem with Omron pressure sensors. I have ordered Farnell part no. 2354010 Pressure sensors 0 to +/-50Pa and received a 0 -  500Pa part. There is an error in your description in the online catalogue. It seems that Farnell catalogue no's 2354010 and 2354011 have been mixed up. Is it possible to replace these parts with the correct sensors? I do not seem to be getting anywhere going through your customer returns procedure. I just end up with the same 0 - 500Pa parts.
    Thanks ChrisK
    chris.kentch@greenwood.co.uk
  • vsluiter
    vsluiter over 12 years ago in reply to e14 Contributor
    Hi Christopher,
    Donna is not going to react, she hasn't been online since 12th of April 2013. Farnell has a possibility to mention errors on their page though (almost top right of page, orange-ish triangle). If you push the 'I need technical help' button someone will be able to redirect you to the correct location to get a replacement.
    Thanks again,
    Chris
    Hello Donna,
      Are these MEMS sensors available as separate devices or are they made as 'captive' products for Omron?   I was wondering about their form-factor, cost and materials compatabiltiy of the raw sensor itself.
    Greg
    If I were to spell EAT on my Tabla, I would tap my pointer finger, tap my thumb, and do a little kick to the 1:30 with the ring finger to get the letter t and you now have EAT! Please check out my site it explains everything! www.thenewkeyboard.com and see the layout at www.tablakey.com. Thank-you for the work you are perfecting. I hope to merge my aeiou alphabetical one hand or two hand split wireless keyboard. I wish to expand my concept to be thought of as a standard for computer input. Your idea blended with a logical and perfect setup. There are more expanded keysets, very logical, AWESOME for disabled, children, artists, really everyone. It is quick to learn and fun to learn! It blows qwerty away! I have left no stone unturned for the perfect layout. I am open to suggestions! But a keyboard layout based on AEIOU, lets face it, its the eureka keyboard! it's the I found it moment! haha. SO, i have a kickstarter that needs a production and fulfillment plan ready and turned back in. How many of these will you have available for market if we make this viral by this Christmas? How much will you want per unit? I will need ten per keyboard plus a moon shaped touch pad, above, and perhaps between the pointer fingers of each hand, so 12 hover responsive regions. I naturally could approach this as a pressure sensitive region without gesturing but I was intrigued by what you are developing!
