Sensors
Sensors
Sensor Forum Do you have a question on MEMS Sensors? Ask our Expert, Donna Sandfox
  • Replies 73 replies
  • Subscribers 353 subscribers
  • Views 10013 views
  • products
  • Mechanical
  • components
  • photomicrosensors
  • sensors
  • expert
  • support
  • omron
  • mems
  • engineering
  • rf
  • switch
  • answers
  • mass_flow
  • vibration
  • question
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Sensors in the element14 Community Sensors group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Donna Sandfox
Donna Sandfox is the Product Manager for Sensors and MEMS Products for Omron Electronic Components LLC.  Her primary area of expertise is in MEMS Mass Flow Sensors.  She also supports Omron’s pressure, thermal IR, tilt/vibration and optical (photomicrosensors) sensors, as well as their RF MEMS Switch products.  Donna received her bachelor’s degree in mechanical engineering from Southern Illinois University and an MBA from Roosevelt University.
    e14 Contributor over 15 years ago in reply to DAB +1
    Hi Don! Thank you, and thanks for the question. While volumes can be written comparing and contrasting all of the different technologies available for measuring gas flow, I'll try to give a reasonably…
    e14 Contributor over 12 years ago in reply to vsluiter +1
    Hello, Thanks for your reply. The problem has now been solved. There was an error in the catalogue which has now been corrected. The correct sensors are with me and ready for test in my project. Thanks…
    DAB over 15 years ago
    Hi Donna,
    Welcome to Element14.
    I know I've been lazy in not researching this myself, but could you explain why the MEMS approach is considered better than existing sensor technology?
    Everyone is talking like its the next best thing since the IPAD, so I am curious where the hype is coming from and what the true merits to the technology might be.
    Hi Don!
    Thank you, and thanks for the question.  While volumes can be written comparing and contrasting all of the different technologies available for measuring gas flow, I'll try to give a reasonably brief answer by limiting it to non-MEMS thermally based mass flow measurement.
    MEMS mass flow sensors are constructed of two sets of thermopiles with a heater between them.  Each thermopile set is comprised of several very small (obviously) thermocouples connected in series.  This design makes the MEMS mass flow chip very sensitive compared to a single set of thermocouples (< 1cm/sec can be measured).  The MEMS chip also has a very fast response time (<5 msec) and low power consumption.
    Omron's MEMS chip employs deep top-etching and dielectric thin layer deposition manufacturing techniques resulting in a high surface area to volume ratio, further improving sensitivity.
    Sometimes seeing is easier than reading; if you'd like to see some graphical representation of what I've described above we have a Product Training Module on our website at:  http://www.components.omron.com/components/web/webfiles.nsf/PTM.html.
    One final note, when constructing a flow sensor... The MEMS chip (or other basic measurement technology) is important, but also are the supporting circuitry (for signal processing and temperature compensation) and the physical design of the flow path (a solid understanding of fluid dynamics is required to ensure good flow characteristics for accurate measurement results).
    Hope this was helpful!
    DAB over 15 years ago in reply to e14 Contributor
    Hi Donna,
    Thanks for the website direction.  I will spend some time getting educated, but I appreciate your quick response.
    Hi Donna -
    I'm designing a device that will have 40 force sensors in a roughly 3" x 4" surface of elastomer. The sensors need to be highly sensitive, so they can detect how hard a user is pushing, from feather light to pretty hard. We also need to take readings from the entire sensor suite at about 30-60Hz. Do you think making my own piezoresitors would be a viable option? I've had difficulty locating sources for Silicon and Germanium, and I'm not sure what type is best or if I could even make the sensors once I had the material.
    Thanks!
    David
    Hello David,
    I admire your ambition on starting from scratch on designing a sensor, though it may be more cost effective to search the marketplace for something already commercially available.  I don't have much experience with Force Sensors, so I'm going to redirect you to an article I found that may give you some ideas on where to start if you don't find what you're looking for.
    http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=5734379
    Regarding manufacturing, I don't know what equipment you have available to you, but there are several MEMS Fabrication companies (assuming you are interested in a MEMS based sensor solution) in existance that already have wafer fabrication equipment in place to service the market.  The MEMS Industry Group website has a listing. From the below link, search Foundry Services.
    http://www.memsindustrygroup.org./custom/buyers_guide/index.cfm
    Best of Luck!
    Donna
    Thanks so much, Donna! I appreciate your help and guidance. The paper sensors are incredibly neat, and that gave me a good start at what to look for. I found these really cool sensors, too : http://www.instructables.com/id/Flexible-Fabric-Pressure-Sensor/#step1
    I bought the materials and got them in one day and was able to make a modified version in under 5 minutes. I used duct tape instead of fabric on the outside, which eliminated the need for sewing. Works great! Low-noise, dirt cheap, easy to make, very sensitive, and the perfect range for my needs!
    Thanks again!
    David
    I want to build a system which monitors water flow from pipeline and detects the clogging if any.
    am unable to find a suitable sensor for this purpose..please help me out..
    regards
    Hello Ajay,
    I do not have much experience with water flow sensors, primarily air/gas types.  Have you investigated ultrasonic type liquid flow meters?  They can be mounted to the outside of your pipe to provide a non-intrusive, no pressure drop, low maintenance solution.
    Hello Donna, I wonder if there exist a sensor regarding muscle contraction.
    Hello Donna,
    I need your advice on how to build a system with a  sensor that will select food products by  the colors and turn a compressor or a separator to separate the red products from the green products, for instance. Need help on where can I find this type of solutions and accesories.
    Need a low cost solution...appreciate your help.
