Sensors
Sensors
Sensor Forum Piezo-ceramics Charge Amplifier
  • Subscribers 348 subscribers
  • Views 1133 views
Hi Guys,
I am in need of a tiny simple charge amplifier to amplify a charge created from a piezo-ceramic and convert it into voltage.
I am using the piezo-ceramic as tiny detector for when applying force, thus I am in need of a charge amplifier.
Where can I find the schematic for one ? and who can create one for me ? can I batch PCB ?
Kind regards,
Pulicaverde
    michaelkellett over 3 years ago in reply to T4lha.30 +2
    Try here: www.researchgate.net/.../260312577_An_electronic_electroscope Lots of designs on the web, some good some bad, this looks OK. The op amp they use is available but expensive, lots more choice…
  • T4lha.30
    T4lha.30 over 3 years ago
    hi sir ,
    have you implemented the charge amplifier if yes can you share its circuit diagram with me please .
    currently i am trying to make a electronic electroscope using a charge amplifier
    Try here:
    The op amp they use is available but expensive, lots more choice if you reduce the power supply to +/- 2.5V but not quite so good or simple.
