Sensors
Sensors
Sensor Forum Xtrinsic sense board output does not change.Raspberry Pi 256 MB. The Xtrinsic sense board, sensors read 0 alt and temp, 64mg for x axis 0 for others, 0 micro t .  I changed gpu memory to 32 MB no joy.  out of ideas, help.  @kd6fvi Bob Smith
  • Subscribers 351 subscribers
  • Views 479 views
@kd6fvi Bob Smith
    Did you ever get this working?   I am having the same issue.  I even tried the manual configuration route with a fresh raspian image and that doesn't work either.   I am seeing the exact same values you are seeing on the output of the python scripts.    I even modified the /etc/modules file to include i2c-bcm2708 and i2c-dev to get the i2c dev files and still no luck....          Next step is to try another raspberry pi board... maybe ours have dead i2c interfaces???
  • kd6fvi
    kd6fvi over 12 years ago in reply to e14 Contributor
    Hi, Have you been able to resolve this, I'm experiencing the same issue with the Xtrinsic Sense Board.
    Any help would be appreciated - andrea
