Sensors
Sensors
Sensor Forum Using MEMS Sensors evaluation board  on Rasberry B+
  • Subscribers 351 subscribers
  • Views 1144 views
  • board
  • raspberry
  • b+
  • sensors
  • mems
Hi all,
Has anybody suceeded in using a MEMS Sensor Evaluation Board on a Raspberry B+?
I'm unable to get the OS to boot with the provided image file with the board connected.It works if disconnected.
I'm able to boot with an installation of Raspian distribution and drivers installed but cannot access to the sensors...I've got a message saying ' bcm 3835 driver init failed'
Is there somebody who can help me?
Thx in advance
  • clem57
    clem57 over 11 years ago
    Did you use this downloaded image: http://downloads.element14.com/sensorboard/sensor_board_1128.zip?ICID=Raspberrypi-Mems-Sensors-Board-Xtrinsic-Board-Spac… Or did you build your own? I would suggest trying the downloaded one to verify no hardware problems first.
    Clem
    e14 Contributor over 11 years ago in reply to clem57
    Hi, yes I've tried with this one
    I used win32diskimager to write it to the sdcard but I can't get the os to boot with the board pluged in or not.
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    Just checking, but you unzipped and used the IMG file as input to win32diskimager. What SD card did you use? how big was it and the class. Sometimes these cards can vary in quality.
    Clem
    hi I've tested with 3 different sdcards and still can't boot
    I've tested with each one with raspian and it works. I just can't boot with the provided image !
    Did you tried mems sensors board with raspberry b+? and did you succeeded?
    thx
    I did.
    At the beginning, I also tried to boot with the provided image, but without success. RPi booted up to login/password, but didn't react to keyboard at all. Then I looked on date of distro and realised it's quite old one, probably based on 3.10 Kernel (RPi B + needs 3.12 or above). So then I just used last one image (Raspbian Wheezy, Kernel version 3.18), and enable I2C bus. Then I'd download examples (git clone http://git.oschina.net/embest/rpi_sensor_board.git), and tested the board. It works Ok.
    Here is quite useful tutorial from @Gough Lui : http://goughlui.com/2014/06/30/getting-started-freescale-xtrinisic-sense-board-on-rpi-kl-25z/
