Sensors
Sensors
Sensor Forum Brainstorm: Basketball Score Keeper
  • Subscribers 351 subscribers
  • Views 1042 views
  • basketball
  • sensor
Hi!
I am working on a basketball hoop that can keep track of the number of shots made. I have made my first iteration and it works well enough. I basically have a long limit switch sticking into the hoop that is attached to an Electric Imp. While this works, the spring has started bending from being hit by a ball repeatedly. I've tried to use a Sharp IR Distance Sensor but it doesn't detect the basketball (I've tried 3 different kinds).
Could potentially use an ultrasonic sensor but it would have to be placed inside of the net because the net would get in the way....right? Any ideas are welcome, I have kind of hit a wall on this!
Thanks!
  • gadget.iom
    0 gadget.iom over 11 years ago
    How about an infrared/laser beam across the centre of the hoop.
    Beam broken = score!
  • gadget.iom
    On further research, it seems that somebody has been able to make it work with a HC-SR04 ultrasonic sensor:
    Arduino Home Basketball Hoop Score Detection System a.k.a. ScoreKeeper
    and one using the previously suggested infrared sensor:
    How To Build an Arcade Style Basketball Game with Arduino
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    Thanks for the links!  I had tried an ultrasonic sensor before but the regulation net is more "dense" than the ones on mini hoops so the sensor doesn't always have a clear view of the inside of the hoop. I could cut away some of the net but I'd like to keep the hoop as standard as possible.
    As for the beam break, I will try this out this week. My only concern is having an LED exposed on the rim where a stray ball could hit it or its wires.
