Sensors
Sensors
Sensor Forum Help trouble shooting new PCB design
  • Subscribers 350 subscribers
  • Views 625 views
  • devices
  • transducer
  • sensor
I started designing a small sonar bottom profiling based off an old design that worked but the manufacturer went out of business and the tech was old and needed improvements. I started by having an electrical engineering company duplicate the original and I had them do it chip for chip resistor for resistor. But when I tested it, it worked, but not correctly.  This is where my electrical expertise ends, you see my background is in mechanical and manufacturing.  So I guess what I want to know is where should I go from here? I am a one person show here so whatever the solution is I hope it isn't to expensive.  I am not opposed to taking on a partner who knows electronics in this as long as they can get it to work. Thanks for your help
  • nickgray
    0 nickgray over 15 years ago
    Hi Matt,
    I am not sure I can help you, but I am an electrical engineer with some experience with sensors. If you send me a private message with your schematic and your geber files of the board, I will try to help you, although I make no promises. I will need to know the frequency range of the input signal that comes into the board.
    Nicholas "Nick" Gray
    0 e14 Contributor over 15 years ago
    Hi Matt
    Have you resolved this problem?
    If not, please get in touch off line.
    Best regards
    Alan
