Sensors
Sensors
Sensor Forum Temperature sensor for MSP430 LaunchPad
  • Subscribers 350 subscribers
  • Views 796 views
  • temperature
  • sensor
I'm looking for temperature sensors for my MSP430 Launchpad.  I'm a software engineer and i'm not very familiar with the hardware.
My project : I want to add an automatic valve to my pool sun-heater system so it opens only when the water that is coming out of the solar panel is warmer than the pool water.  One of the temperature sensor will be places on the solar panels and the other one will be in the pool water.
Do you have any suggestions on what I should buy to do that (temperature sensor model that will fit on the MSP430 Launchpad) ?
thanks you image
  • Catwell
    0 Catwell over 14 years ago
    Fred, welcome to element14.
    Get a thermistor or thermocouple
    House it in something waterproof
    Connect it to the Launchpad's 8bit ADC
    Software wise, set temperature ranges to activate other devices
    Fish tank equipment have done this for decades. I would refrain from using common fishtank thermostats, they often use AC up to a point. You do not want to electrify your pool.
    Cabe
    http://twitter.com/Cabe_e14
    0 DAB over 14 years ago
    Hi Fred,
    Take a look at the new temperature launch pad board for the MSP430.  It came out last month and fits onto your launchpad with a very accurate and stable measurement capability.
    You can also monitor the water temperature with an aluminum rod set into the pool with your temperature sensor attached to the rod with lithium grease.  The rod temperature will accurately reflect the water temperature and keeps your electronics far from harm.
    Just a thought,
    0 e14 Contributor over 13 years ago in reply to DAB
    An LM34/LM35 is a linear temperature sensor that is commonly available and cheap ($1.00).
