Sensors
Sensors
Sensor Forum Rotation sensor for treadmill roller
  • Subscribers 348 subscribers
  • Views 805 views
jayhawkins
jayhawkins over 11 years ago
Looking for a very low voltage rotation sensor for a modification I'm doing to a manual treadmill. What part would you suggest I look at?
Jay
    0 dougw over 11 years ago
    couple of companies make Hall effect rotation sensors:
    Melexis MLX90316
    Allegro Microsystems A1332
    There are also magnetoresistive rotational speed sensors such as NXP's KMI 16 and KMI 17
    Magnetic pickup sensors are older technology available from many suppliers, but you can make your own with a magnet, a coil of wire and a steel rod (nail). These do not require any power, but the signal at low speed may be small.
    Similarly a capacitance pickup can sense nearby metal gears.
    Rotary capacitor sensors can also be used.
    Another technology is an optical encoder.
    0 jw0752 over 11 years ago
    Hi Jay,
    Have you given any thought to using a magnetic reed switch. It will close each time a magnet passes it and it will operate at any voltage. The pulses can be counted and using the diameter of the treadmill roller you can calculate speed or even acceleration.
    http://en.wikipedia.org/wiki/Reed_switch
  • jayhawkins
    0 jayhawkins over 11 years ago in reply to dougw
    Thanks Douglas. I was actually looking at the NXP products. This is a pretty exciting space, but I've always been a programmer on the business side of things, not the device. A lot of learning to do. This is a whole new paradigm.
    I really appreciate your input. I'm flying kind of blind here.
    Jay
