Sensors
Sensors
Sensor Forum Please help me to choose cable to extend TO-92 sensor legs
  • Replies 23 replies
  • Answers 2 answers
  • Subscribers 347 subscribers
  • Views 4277 views
  • TO-92
  • cable lead
HKPhysicist
HKPhysicist over 1 year ago
Hello E/E Engineers,
I am in the way of choosing cables to extend this TO-92 type temperature sensor legs so that I can place it under the target battery or even extend it into a refrigerator / freezer.
MCP-9700A
I know there is out-of-box 1-wire sensor packaged with long cable lead but the part`s origin is in question.  I must create this by myself so that I have the part`s origin documents.
    michaelkellett over 1 year ago in reply to HKPhysicist +4
    That isn't a problem. You can calculate exponentials on pretty much any modern micro but its a little slow. If you want to conserve power or time then precalculate third order polynomial coefficients from…
  • rsc
    rsc over 1 year ago in reply to HKPhysicist +3
    Since the drain wire is connected to the shielding, it's more of a ground than a shield, but since the other wires are twisted pair it should work..
  • kmikemoo
    kmikemoo over 1 year ago in reply to HKPhysicist +3 suggested
    HKPhysicist You can always go with one of the Maker's best friend - hot glue. That's what I used way back in 2021 during Build Inside The Box . I'm not sure how much it will shrink in the cold, but at…
  • anniel747
    0 anniel747 over 1 year ago in reply to HKPhysicist
    Epoxy or UV?
    0 shabaz over 1 year ago in reply to HKPhysicist
    I would say you're over-thinking it. Almost any adhesive or sealant would be fine, provided it's not (very) conductive. You mention fast-drying; if it were me, I'd use a dab of Araldite Rapid, it's easily available and inexpensive (compared to industrial adhesives or sealants) and sets fast.
    Since you have a cable egressing, you'll need a bit of flexibility plus strain relief as well as water-proofness there, and all three of those are easily handled with a small length of typical adhesive-lined heatshrink sleeving.
  • kmikemoo
    0 kmikemoo over 1 year ago in reply to HKPhysicist
    HKPhysicist You can always go with one of the Maker's best friend - hot glue.  That's what I used way back in 2021 during Build Inside The Box.  I'm not sure how much it will shrink in the cold, but at low volumes of glue, it shouldn't be that much.
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to kmikemoo
    Hello Friend,
    Thanks for your opinion.  I am glad you also use MCP9700.  It is cheap with good precision. Slight smile
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to shabaz
    Hello Shabaz,
    Thanks for your recommendation.
    I have found this in Element14:
    https://hk.element14.com/araldite/ara400001/adhesive-epoxy-2-15ml-yellow-tube/dp/2079740
    That will work, although that's the slow-set version. If you can find it elsewhere in your region (it doesn't appear to be available at the hk.element14 site), there is an approx 5-minute set time version called Araldite Rapid. There's also a 90-second set version (Araldite Instant), that's convenient too. They are generally available, not specialist, so they may be available via Amazon.
    0 shabaz over 1 year ago in reply to anniel747
    I sometimes use what I believe is nail adhesive, it's thick as if it were a clear type of putty, with a UV torch. Very convenient!
  • anniel747
    0 anniel747 over 1 year ago in reply to shabaz
    shabaz You may be right that the same UV adhesive is marketed for many uses.
  • robogary
    0 robogary over 1 year ago
    Thanks for the question. Ive been typically using PTD and NTD thermistors, didnt know these devices even existed.  One supplier listed them as digital, but datasheet says analog, Im going with the datasheet.
    I've started a project that uses thermistors, but seeing this device, I'm changing it to these TO-92.
    Stopping by to say THANKS !
    0 michaelkellett over 1 year ago in reply to HKPhysicist
    Try using adhesive coated heat-shrink tube.
    Use a piece long enough to give overlap onto the cable and beyond the sensor.
    Heat it and it will stick to the cable on its own, while it's still hot and the glue inside is molten crimp the other end with pliers so it seals up.
    The picture below illustrates the technique but on a rather larger scale:
