Sensors
Sensors
Sensor Forum IoT sensor on Communication mast
  • Replies 21 replies
  • Subscribers 344 subscribers
  • Views 4026 views
  • reality
  • sensors
  • detection
  • transducer
  • iot
  • new_applications
corel_draw
corel_draw over 1 year ago
I am working on a pilot use case of AI-IoT  and I would appreciate feedback.
In particular, I am looking at the feasibility of deploying IoT sensors/sensors on communication mast - these sensors might be gateways that connect to
other distributed low-cost  sensors within a locality. The usage of this sensor network could range from air quality monitoring, traffic analysis (for example
using Bluetooth signals), waste management etc. My questions
  1. Are there potential pitfalls (technical and otherwise) of this system or better ways to rethink the system ?
  2. If deployed in a local area as a paid  service, can the model sustain itself and also generate revenue
  3. Is this a totally irrelevant idea and doomed to fail.
    Thank you!
  • obones
    obones over 1 year ago +3
    You mean, you want to come 5 to 10 years late to the LoRaWan market? In my area, all the water meters are remotely read and they use LoRaWan repeaters located on street signs or lamppost every 50 to…
  • BigG
    BigG over 1 year ago in reply to obones +3 verified
    There are other companies like Birdz scattered around the world.All doing similar things. Key is customer engagement to get "locked in". You can also leverage open source to do it: https://meshtastic…
    michaelkellett over 1 year ago +2
    Definitely 3, adding AI to any acronym is a full guarantee of failure. MK
    0 michaelkellett over 1 year ago
    Definitely 3,
  • corel_draw
    0 corel_draw over 1 year ago in reply to michaelkellett
    True! for the AI part. Though this is not necessarily always the case. In this instance, we could just assume AI to be a fancier name for machine learning.
    For definitely 3, would you kindly enlighten me more - in particular what might be missing.
    +1 Jan Cumps over 1 year ago
    To answer question 2, you 'd have to know your potential customers / investors, and what they would be willing to pay for your service.
  • anniel747
    0 anniel747 over 1 year ago
    [deleted]
  • corel_draw
    0 corel_draw over 1 year ago in reply to anniel747
    1) Yes, there are existing literature that have extensively discussed deployment of bluetooth for traffic management, so it is not something new. And yes, the deployment is for where such systems do not exist. City planners would definitely be willing to pay for example
    2) Yes! there are users who are willing to pay for that especially where such systems do not already exist. And these are example use cases
    3) Could you kindly elaborate,
  • corel_draw
    0 corel_draw over 1 year ago in reply to Jan Cumps
    There are users who are willing to pay  based on similar existing prototype.
    0 Jan Cumps over 1 year ago in reply to corel_draw
    Do you know how much they pay? And if they would be interested in purchasing from you?
    I think it is unrealistic that they will engage with an unknown entity for a contract. If you can build it as one person, one of the settled suppliers will be able to build something similar fast. Unless you have something very compelling and very unique.
  • corel_draw
    correct! the central focus here is critique of approach and its relevance. For sure, they can approach settled suppliers, very true. As in any such deployment/idea, there is always opportunity to carve some niche in the market while  the bigger players take the bigger chunk.
  • corel_draw
    No.
    Until I deploy my own and make a pilot test.
    They would probably be willing if the QoS is good enough.  I will probably  have services that are billed across different cost range to accommodate wide range of users and have a niche customer base.
