Sensors
Sensors
Sensor Forum What got stuck to my shoe
  • Replies 20 replies
  • Subscribers 348 subscribers
  • Views 2854 views
  • sensor
colporteur
colporteur over 1 year ago
I received a shipment of TCA9548A multiplexes in an anti-static bags. Slip in between the folds of one of the packages was this module. I suspect it is a long lost chip trying to find it way home. I've been unsuccessful in discovering what it is, so I can't give it purpose. Any suggestions?
The silver package to the left has the markings 1244 U401 001. The black components towards the top od the PCB has LB2K. There are no components or markings on the back of the board.
Anyone see this beast before?
The dimension of the board is 1cm square. It came with a five pin header not soldered.
  • colporteur
    colporteur over 1 year ago +2
    Holds promise gents. Similar numbers on the can.
    shabaz over 1 year ago +1
    Maybe it's a pressure sensor, e.g. like Bosch BMP280 or similar. I'd recommend building this sometime (it's easy, just a few wires and two resistors connected to a Pi Pico, and drag-and-drop programming…
  • aswinvenu
    aswinvenu over 1 year ago in reply to colporteur +1
    I found this online. Looks identical except the marking has some difference. I would assume it would be the batch ID difference. https://robu.in/product/bmp180-digital-barometric-pressure-sensor-module…
    shabaz over 1 year ago in reply to beacon_dave
    I think their search is broken. Searching for ULN2804A gets converted by the site into a search for 'darlington transistors', and it finds 86 of them, of which eight are categorized as ICs. Those eight are missing the UN2804A. Anyway, not going to raise this with the team, because it's just too irritating. This should be automated, they ought to have rules for alerts (and internal logs) to be generated when silly things like this happen, when the search results do not contain the item actually requested!
    dougw over 1 year ago
    Nice score. I need to start checking packing materials more closely.....Relaxed
  • beacon_dave
    beacon_dave over 1 year ago in reply to shabaz
    The quick search finds it:
    The search engine can be painful at times - I often know there is something in there but it just won't find it, unless you know the exact order code.
    dougw over 1 year ago in reply to beacon_dave
    The spotty cross referencing system often makes it tough to drill down to what you are looking for. Probably a good candidate for some AI.
  • beacon_dave
    beacon_dave over 1 year ago in reply to dougw
    "...Probably a good candidate for some AI..."
    I can just picture it now Slight smile
    "... You appear to be looking for a 555 timer IC.
         We recommend this ULN2804A darlington array... "
  • beacon_dave
    I once received ≈20 rolls of 50mm wide adhesive copper tape instead of gaffer tape.
    The weight of the box was a bit of a surprise upon delivery.
    ( A bit difficult to tear by hand but handy for additional screening of cable runs. )
    shabaz over 1 year ago in reply to shabaz
    (Updated that project, so that it's possible to check a database of about 700 I2C device names).
  • colporteur
    Thanks folks for discovering the suppliers flotsam and jetsam, not sure which it is. Further investigation of the device is taking a back seat to five other projects on board.
    The E14 community is kinda like AI. Ask it a formulated question get a useful response. Thanks again.
    DAB over 1 year ago
    Interesting.
    With parts getting smaller and smaller, it makes it more difficult to package and send them.
  • JWx
    JWx over 1 year ago in reply to colporteur
    searching for this photo using Google Lens returns link from AliExpress with description: "GY-68 BMP180 digital pressure sensor"
