Sensors
Sensors
Sensor Forum having a problem with LM35 temperature sensor
  • Replies 39 replies
  • Subscribers 346 subscribers
  • Views 5580 views
  • sensors
  • arduino ide
  • temperature sensor
  • analog
samiboutgoulla
samiboutgoulla over 1 year ago
Hello, I just started a project with LM35 (temperature sensors) with Arduino, after mounting it on my breadboard I noticed that the values ​​in the serial monitor are inconsistent and vary in a strange way, for example I get 21°, 20°, 22° 24° successively which is impossible I get the same result with 5 different sensors,  even whern i use a heat source the temperature the values vary also in a strange way and I don't know where the problem is can someone help me please? image imageimage
    michaelkellett over 1 year ago in reply to samiboutgoulla +3
    It looks as if you have no resistor from the output to a negative bias voltage - this means that you will get poor results as the temperature drops towards zero but you can ignore that for now. The sensor…
  • kmikemoo
    kmikemoo over 1 year ago +3
    samiboutgoulla You can try one of the circuits below. They are taken from the LM35 datasheet. The capacitance of your breadboard may be impacting your readings. Still... shabaz's video is very compelling…
    michaelkellett over 1 year ago in reply to JWx +1
    Good idea but I think he has an external noise problem - let's wait and see ! MK
    0 michaelkellett over 1 year ago in reply to Jan Cumps
    He uses red for ground just to test us !
    0 michaelkellett over 1 year ago in reply to samiboutgoulla
    Unless its very hot in your lab just holding the sensor with your fingers should warm it up a bit.
    The lighter could get a bit too hot.
  • samiboutgoulla
    0 samiboutgoulla over 1 year ago in reply to Robert Peter Oakes
    ok i will try ty
  • samiboutgoulla
    0 samiboutgoulla over 1 year ago in reply to michaelkellett
    i'm from morocco , i notice a thing even when i'm approching heat source the temperature don't raise
  • samiboutgoulla
    i even notice that tempreature wes decreasing when approching a heat source instead of increasing
    0 dougw over 1 year ago
    The pins on these sensors are a bit thin to be sure of a good connection in a breadboard.
    One thing to try is just measure the sensor output voltage with a DVM as a heat source is applied.
    Measuring at the sensor will indicate if the sensor is connected properly and working.
    Measuring at the Arduino will indicate if the connections are good.
    If you have a scope, you might be able to see how much noise is on the signal.
    0 shabaz over 1 year ago
    There' also might be a good chance of something like this:
    https://youtu.be/NiNTDKKATmo?feature=shared
  • kmikemoo
    0 kmikemoo over 1 year ago
    Still... shabaz's video is very compelling.
    I have been bitten by fake temperature sensors before as well...
