Sensors
Sensors
Sensor Forum having a problem with LM35 temperature sensor
  • Replies 39 replies
  • Subscribers 346 subscribers
  • Views 5558 views
  • sensors
  • arduino ide
  • temperature sensor
  • analog
samiboutgoulla
samiboutgoulla over 1 year ago
Hello, I just started a project with LM35 (temperature sensors) with Arduino, after mounting it on my breadboard I noticed that the values ​​in the serial monitor are inconsistent and vary in a strange way, for example I get 21°, 20°, 22° 24° successively which is impossible I get the same result with 5 different sensors,  even whern i use a heat source the temperature the values vary also in a strange way and I don't know where the problem is can someone help me please? image imageimage
    michaelkellett over 1 year ago in reply to samiboutgoulla +3
    It looks as if you have no resistor from the output to a negative bias voltage - this means that you will get poor results as the temperature drops towards zero but you can ignore that for now. The sensor…
  • kmikemoo
    kmikemoo over 1 year ago +3
    samiboutgoulla You can try one of the circuits below. They are taken from the LM35 datasheet. The capacitance of your breadboard may be impacting your readings. Still... shabaz's video is very compelling…
    michaelkellett over 1 year ago in reply to JWx +1
    Good idea but I think he has an external noise problem - let's wait and see ! MK
  • samiboutgoulla
    0 samiboutgoulla over 1 year ago in reply to michaelkellett
    i'm from morocco , i notice a thing even when i'm approching heat source the temperature don't raise
    0 michaelkellett over 1 year ago in reply to samiboutgoulla
    Do you have any way of measuring voltage  ?
    0 Jan Cumps over 1 year ago in reply to samiboutgoulla
    GND and 5V mixed at the Arduino?
  • samiboutgoulla
    i'm searching for a voltemetre , another thing i approched a lighter to lm35 the tempreature start decreasing
  • samiboutgoulla
    0 samiboutgoulla over 1 year ago in reply to Jan Cumps
    no i verfied there no problem with connections
  • samiboutgoulla
    0 samiboutgoulla over 1 year ago in reply to JWx
    i noticed a thing temperature start decreasing instead on increasing when approching a source of heat
  • samiboutgoulla
    another thing i approched a lighter to lm35 the tempreature start decreasing , i repeated it many times and the temperature is decreasing for sure
    It helps, for photos, if you use black for ground and red for +5V. You 'll confuse the people that try to help, and yourself eventually.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 1 year ago in reply to samiboutgoulla
    just a thought, have you checked the jumper cables are good, they look like banggood/alliexpress/amazon cheapies brand and I have had very poor results myself with them to the point were i will check every one with a dmm to be sure they are at or near 0 Ohms, I have found a very high percentage to be hundreds of ohms or more because of bad manufacturing and has caused me all sorts of problems in the past. get three wires strip the ends and use that instead just to test if you dont have a way to check them
    0 Robert Peter Oakes over 1 year ago in reply to Robert Peter Oakes
    even ones with dupont connectors have had rust or really bad crimps too, not just those molded ones.
