Test & Tools
Test & Tools
Blog Battery tester schematic
  • Author Author: Eavesdropper
  • Date Created: 19 Apr 2011 7:13 PM Date Created
  • Views 5471 views
  • Comments 7 comments
  • test
  • battery_tester
  • battery
  • eavesdropper
  • capacity
  • measurement
Eavesdropper
Eavesdropper
19 Apr 2011
E. Lelic has given out a battery tester circuit, controlled by a PIC 16F88PIC 16F88, that can charge, discharge, measure internal resistance, and capacity of Li ON, Li Po, Ni Cd, Ni Mh, and regular cell batteries.
Capacity is measures through the logging of how much mAhs the battery has accepted. Charging can be started at stopped at will, and switched to discharging if need be. Over-charging protection is built in. Lelic states that we should not trust what the batteries are rated at, and instead test to validate. This definitely would be handy to test so called "extended batteries" for our many gadget.
I took the liberty of downloading the schematic for Lelic's tester.  Enjoy.
Eavesdropper
    e14 Contributor over 11 years ago +1
    Hi, I built it and it worked fine. So I choose to build my own pcb; I finish the CAD routing and see below results.
    e14 Contributor over 15 years ago in reply to hammerhead46
    The original article is linked here, but it's tough to see ("E. Lelic" is linked at the beginning of this post). That's where the code is that you're looking for (http://www.elektronika.ba/795/smart-battery-tester-and-charger/).
  • hammerhead46
    hammerhead46 over 15 years ago
    Where can I find the program for the "PIC16F88"?
