Test & Tools
Test & Tools
Blog Bluetooth LE Transmit Testing with the FPC1500 - BLE Development Boards
  • Author Author: ralphjy
  • Date Created: 20 Jun 2022 5:44 PM Date Created
  • Views 7293 views
  • Likes 12 likes
  • ble transmitter testing
  • BLEFPC1500
  • Rohde&Schwarz FPC1500
ralphjy
ralphjy
20 Jun 2022
Table of Contents
Blog 1: Bluetooth LE Transmit Testing with the FPC1500
Blog 2: Getting Started
Blog 3: BLE Development Boards
Blog 4: Test Development
Blog 5: ESP32 Measurements
Blog 6: nRF52 Measurements
Blog 7: CYW43-measurements
Blog 8: Summary
Over the years of my IoT journey, I've made the connectivity progression from wired (Serial, USB, Ethernet) to wireless (WiFi b/g/n, Bluetooth BR/EDR) to low power wireless (BLE, LoRa) and have recently added cellular (LTE-M and LTE-CAT1) into the mix.
For short range battery operated devices (primarily remote sensors), I prefer to use BLE.  I use it for both data and control, either interfacing to a tablet or cellphone using a mobile app or a laptop/desktop using WebBLE or a Cloud Dashboard.
As a result, I have a large collection of development boards and sensors using BLE - usually in combination with WiFi.  I did a quick survey of board types that I've used with respect to the device used for BLE (if the device is on a module - I listed the Module type).  Not a complete list, but a good representation of the boards I use.  Three chipset manufacturers stand out - Espressif (ESP32), Nordic (nRF), and Infineon (CYW).  That's probably because of the type of boards that I buy and the development frameworks that I use.  When I started out with WiFi, I used a lot of boards with the Espressif ESP8266 - primarily because they were very low cost and widely available.  I moved to the ESP32 for higher performance and that provided an easy migration path from WiFi to BLE using the same boards.  I've recently been using a lot more Nordic based boards due to their good low power performance and excellent application support.
BLE Device
Antenna
Other RF
ESP32
Adafruit HUZZAH32
PCB
WiFi b/g/n
M5Stack StickC
Internal
WiFi b/g/n
M5Stack StickC Plus
Internal
WiFi b/g/n
Sparkfun ESP32 Thing
PCB
WiFi b/g/n
Sparkfun ESP32 Thing Plus
U.FL
WiFi b/g/n
NINA W102 (ESP32)
Arduino MKR WiFi 1010
PCB (PIFA)
WiFi b/g/n
Arduino Nano 33 IoT
PCB (PIFA)
WiFi b/g/n
Arduino Nano RP2040 Connect
PCB (PIFA)
WiFi b/g/n
Arduino Vidor 4000
PCB (PIFA)
WiFi b/g/n
nRF52840
Nordic nRF52840 USB Dongle
PCB
Nordic Thingy:91
Internal
LTE-M (nRF9160)
RAKwireless RAK4631
U.FL
LoRa (SX1262)
Seeed XIAO BLE nRF52840
Chip
Seeed XIAO BLE nRF52840 Sense
Chip
Sparkfun Micromod nRF52840
PCB
NINA B306 (nRF52840)
Arduino Nano 33 BLE Sense
PCB
ANNA-B112 (nRF52832)
Arduino Nicla Sense ME
Chip
nRF51822
Adafruit BLE Friend UART
PCB
Microbit v1
PCB
nRF52833
Microbit v2
PCB
nRF5340
Nordic nRF5340 DK
PCB
Murata 1DX (CYW4343W)
Arduino Portenta H7
U.FL
WiFi b/g/n
Infineon CY8CKIT-062-WIFI-BT
Chip
WiFi b/g/n
Murata 1LV (CYW43012)
Infineon CY8CKIT-062S2-43012
Chip
WiFi b/g/n
CYW43455
RPi3A+
PCB
WiFi b/g/n
RPi3B+
PCB
WiFi b/g/n
RPi4B
PCB
WiFi b/g/n
BCM43438
RPi3B
PCB
WiFi b/g/n
RPi Zero W
PCB
WiFi b/g/n
SYN43436
RPi Zero 2 W
PCB
WiFi b/g/n
RTL8720DN
Seeed Wio Terminal
Internal
WiFi b/g/n
RTL8722DM
Ameba RTL8722DM Mini
Internal
WiFi b/g/n
A few of the boards:
For the purposes of this demonstration project, I would like to develop a test methodology that I can use with the 3 main device types that I use (ESP32, nRF, and CYW).  I'll start with the ESP32 since I have the most experience with that device.  The Sparkfun ESP32 Thing Plus has an external U.FL antenna port that provides me with the ability to use either a direct cable connection or antennas to connect to the FPC1500 (note: there is another version of this board that uses an ESP32 module with a PCB antenna).
With omnidirectional antenna:
I have a variety of external antennas that I could try ( a few different omnidirectional "rubber duck" antennas with various gains and some dual band WiFi antennas from a Molex sample kit).  I'll probably save that for an addendum to this project.
Dual Band 2.4/5GHz antennas from Molex sample kit:
In the next post I'll get into the detail of programming the ESP32 and connecting to and configuring the FPC1500.
  • fmilburn
    fmilburn over 4 years ago +1
    That is an impressive collection :-)
  • neilk
    neilk over 4 years ago
    WOW!! What a lot!!!
  • neilk
    WOW!! What a lot!!!
